Enable additional UARTs on Colibri iMX7
I am trying to enable additional UARTs on Colibri iMX7D but I have not been successful so far.
I have created two new DTS files (one for carrier board itself, the other one for iMX7D module in this carrier board) in the same manner as DTS files for evaluation board are done.
imx7-colibri-janom-imp-rev0.dtsi
	chosen {
		bootargs = "console=ttymxc0,115200";
&iomuxc {
	pinctrl-names = "default";
	imx7d-colibri {
		pinctrl_uart5: uart5grp {
			fsl,pins = <
				MX7D_PAD_SAI2_TX_BCLK__UART4_DTE_RX	0x79
				MX7D_PAD_SAI2_TX_SYNC__UART4_DTE_TX	0x79
&uart1 {
	pinctrl-0 = <&pinctrl_uart1>;
	/delete-property/ fsl,uart-has-rtscts;
&uart2 {
&uart3 {
&uart5 {
	pinctrl-0 = <&pinctrl_uart5>;
	fsl,dte-mode;
imx7d-colibri-janom-imp-rev0.dts
/dts-v1/;
#include "imx7d-colibri.dtsi"
#include "imx7-colibri-janom-imp-rev0.dtsi"
	model = "Toradex Colibri iMX7D on Janom IMP rev.0";
	compatible = "egmedical,colibri_imx7d-janom_imp", "toradex,colibri_imx7d", "fsl,imx7d";
I believe that the syntax is correct, but Device Tree Compiler says otherwise. I receive following error when trying to compile DTS file:
Error: /home/yocto/colibri-imx7/oe-core/build/tmp-glibc/work-shared/colibri-imx7/kernel-source/arch/arm/boot/dts/imx7d-colibri-janom-imp-rev0.dts:5.1-2 syntax error
FATAL ERROR: Unable to parse input tree
scripts/Makefile.lib:293: recipe for target 'arch/arm/boot/dts/imx7d-colibri-janom-imp-rev0.dtb' failed
make[3]: *** [arch/arm/boot/dts/imx7d-colibri-janom-imp-rev0.dtb] Error 1
arch/arm/Makefile:322: recipe for target 'imx7d-colibri-janom-imp-rev0.dtb' failed
make[2]: *** [imx7d-colibri-janom-imp-rev0.dtb] Error 2
Makefile:146: recipe for target 'sub-make' failed
make[1]: *** [sub-make] Error 2
Makefile:24: recipe for target '__sub-make' failed
make: *** [__sub-make] Error 2
WARNING: exit code 1 from a shell command.
The error happens on line 5, typically you want to look at the line just before that. In your case the line just before that is an include, so you want to look at the last line of that included file.
Your last node is missing a semicolon ;
&uart5 {
     fsl,dte-mode;
@stefan.tx: Thanks for pointing that out, that was rather stupid mistake.
