While interfacing the i.MX6 with the eMMC card, the card is detected, but I am experiencing reading errors and I/O errors. What are the possible solutions to address these issues?
Based on the context provided, it seems that the i.MX6 modules with Macronix eMMC might be affected by a “Forced Read Only Mode” issue. If you are experiencing reading errors and I/O errors, it could be related to this known issue with certain production batches of the Macronix eMMC (MX52LM04A11XUI).
Here are some steps you can take to address these issues:
Check for Forced Read Only Mode: Use the provided tools and instructions to check if your module is affected by the Forced Read Only Mode issue. This involves running a check tool on your module to determine if a fix is needed.
Repair Procedure: If your module is affected, follow the repair procedure. This can be done by downloading and running an automatic fix image or using recovery mode to repair the eMMC. Ensure that the affected eMMC is not used to boot the module during this process.
Contact Toradex Support: If the procedure fails or if you need further assistance, it is recommended to contact Toradex support for help.
If the issue is not related to the Forced Read Only Mode, there might be other causes for the reading errors, such as hardware connections, power supply issues, or software configuration problems. However, based on the context, the Forced Read Only Mode is a likely cause.
Any other solutions to solve this problem
Hi @saivenkatesh019,
Requesting you to please use your official email/company email for your account.
