I’m designing a Colibri carrier board and I need the power consumption of all compatible SOM with Colibri family. In some datasheets, in the Typical Power Consumption, appear the term “TBD” instead of the current value. What is “TBD” mean?
To be defined
Thank you Alex.
You are welcome.
For the power design of your carrier board, you should refer to the Carrier Board Design Guide.
