Hi @diego_b.tx ,
Yes I have the eglinfo-fb on the target
EGL information:
API version: 1.5
vendor string: Vivante Corporation
version string: 1.5
client APIs: OpenGL_ES OpenVG
extensions:
EGL_KHR_fence_sync
EGL_KHR_reusable_sync
EGL_KHR_wait_sync
EGL_KHR_image
EGL_KHR_image_base
EGL_KHR_image_pixmap
EGL_KHR_gl_texture_2D_image
EGL_KHR_gl_texture_cubemap_image
EGL_KHR_gl_renderbuffer_image
EGL_EXT_image_dma_buf_import
EGL_EXT_image_dma_buf_import_modifiers
EGL_KHR_lock_surface
EGL_KHR_create_context
EGL_KHR_surfaceless_context
EGL_EXT_buffer_age
EGL_ANDROID_native_fence_sync
EGL_KHR_partial_update
number of configurations: 60
win = window (c) = conformant slow = slow config gl = Desktop OpenGL
pb = pbuffer (n) = non-conformant nonconfmt = non-conformant config es1,es2 = OpenGL ES 1.x/2.x
pix = pixmap vg = OpenVG
# ID LEVEL COLORBUFFER.......... DEPTH STENCIL MULTISAMPLE.... VISUAL....... SURFACES.. RENDERABLES...................... TRANSPARENT.. CAVEAT...
type size r g b a size size samples buffers type id apis native type r g b
0 1 0 rgb 12 4 4 4 0 0 0 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
1 2 0 rgb 12 4 4 4 0 0 8 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
2 3 0 rgb 12 4 4 4 0 16 0 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
3 4 0 rgb 12 4 4 4 0 24 0 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
4 5 0 rgb 12 4 4 4 0 24 8 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
5 6 0 rgb 12 4 4 4 0 0 0 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
6 7 0 rgb 12 4 4 4 0 0 8 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
7 8 0 rgb 12 4 4 4 0 16 0 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
8 9 0 rgb 12 4 4 4 0 24 0 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
9 10 0 rgb 12 4 4 4 0 24 8 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
10 11 0 rgb 15 5 5 5 0 0 0 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
11 12 0 rgb 15 5 5 5 0 0 8 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
12 13 0 rgb 15 5 5 5 0 16 0 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
13 14 0 rgb 15 5 5 5 0 24 0 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
14 15 0 rgb 15 5 5 5 0 24 8 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
15 16 0 rgb 15 5 5 5 0 0 0 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
16 17 0 rgb 15 5 5 5 0 0 8 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
17 18 0 rgb 15 5 5 5 0 16 0 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
18 19 0 rgb 15 5 5 5 0 24 0 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
19 20 0 rgb 15 5 5 5 0 24 8 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
20 21 0 rgb 16 4 4 4 4 0 0 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
21 22 0 rgb 16 5 6 5 0 0 0 0 0 0x0010 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
22 23 0 rgb 16 4 4 4 4 0 8 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
23 24 0 rgb 16 5 6 5 0 0 8 0 0 0x0010 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
24 25 0 rgb 16 4 4 4 4 16 0 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
25 26 0 rgb 16 5 6 5 0 16 0 0 0 0x0010 0x0000 win,pb,pix es1(c),es2(c),vg(n) yes none -1 -1 -1 none
26 27 0 rgb 16 4 4 4 4 24 0 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
27 28 0 rgb 16 5 6 5 0 24 0 0 0 0x0010 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
28 29 0 rgb 16 4 4 4 4 24 8 0 0 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
29 30 0 rgb 16 5 6 5 0 24 8 0 0 0x0010 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
30 31 0 rgb 16 4 4 4 4 0 0 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
31 32 0 rgb 16 5 6 5 0 0 0 4 1 0x0010 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
32 33 0 rgb 16 4 4 4 4 0 8 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
33 34 0 rgb 16 5 6 5 0 0 8 4 1 0x0010 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
34 35 0 rgb 16 4 4 4 4 16 0 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
35 36 0 rgb 16 5 6 5 0 16 0 4 1 0x0010 0x0000 win,pb,pix es1(c),es2(c),vg(c) yes none -1 -1 -1 none
36 37 0 rgb 16 4 4 4 4 24 0 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
37 38 0 rgb 16 5 6 5 0 24 0 4 1 0x0010 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
38 39 0 rgb 16 4 4 4 4 24 8 4 1 0x3038 0x0000 win,pb es1(c),es2(c) no none -1 -1 -1 none
39 40 0 rgb 16 5 6 5 0 24 8 4 1 0x0010 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
40 41 0 rgb 24 8 8 8 0 0 0 0 0 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
41 42 0 rgb 24 8 8 8 0 0 8 0 0 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
42 43 0 rgb 24 8 8 8 0 16 0 0 0 0x0020 0x0000 win,pb,pix es1(c),es2(c),vg(n) yes none -1 -1 -1 none
43 44 0 rgb 24 8 8 8 0 24 0 0 0 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
44 45 0 rgb 24 8 8 8 0 24 8 0 0 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
45 46 0 rgb 24 8 8 8 0 0 0 4 1 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
46 47 0 rgb 24 8 8 8 0 0 8 4 1 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
47 48 0 rgb 24 8 8 8 0 16 0 4 1 0x0020 0x0000 win,pb,pix es1(c),es2(c),vg(c) yes none -1 -1 -1 none
48 49 0 rgb 24 8 8 8 0 24 0 4 1 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
49 50 0 rgb 24 8 8 8 0 24 8 4 1 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
50 51 0 rgb 32 8 8 8 8 0 0 0 0 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
51 52 0 rgb 32 8 8 8 8 0 8 0 0 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
52 53 0 rgb 32 8 8 8 8 16 0 0 0 0x0020 0x0000 win,pb,pix es1(c),es2(c),vg(n) yes none -1 -1 -1 none
53 54 0 rgb 32 8 8 8 8 24 0 0 0 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
54 55 0 rgb 32 8 8 8 8 24 8 0 0 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
55 56 0 rgb 32 8 8 8 8 0 0 4 1 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
56 57 0 rgb 32 8 8 8 8 0 8 4 1 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
57 58 0 rgb 32 8 8 8 8 16 0 4 1 0x0020 0x0000 win,pb,pix es1(c),es2(c),vg(n) yes none -1 -1 -1 none
58 59 0 rgb 32 8 8 8 8 24 0 4 1 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
59 60 0 rgb 32 8 8 8 8 24 8 4 1 0x0020 0x0000 win,pb,pix es1(c),es2(c) yes none -1 -1 -1 none
No valid context: EGL failed to allocate resources for the requested operation.
eglMakeCurrent() failed: Arguments are inconsistent (for example, a valid context requires buffers not supplied by a valid surface).
OpenGL ES 2 information:
version string: OpenGL ES 3.0 V6.2.4.p4.190076
renderer string: Vivante GC880
extensions:
GL_OES_vertex_type_10_10_10_2
GL_OES_vertex_half_float
GL_OES_element_index_uint
GL_OES_mapbuffer
GL_OES_vertex_array_object
GL_OES_compressed_ETC1_RGB8_texture
GL_OES_compressed_paletted_texture
GL_OES_texture_npot
GL_OES_rgb8_rgba8
GL_OES_depth_texture
GL_OES_depth_texture_cube_map
GL_OES_depth24
GL_OES_depth32
GL_OES_packed_depth_stencil
GL_OES_fbo_render_mipmap
GL_OES_get_program_binary
GL_OES_fragment_precision_high
GL_OES_standard_derivatives
GL_OES_EGL_image
GL_OES_EGL_sync
GL_OES_required_internalformat
GL_OES_surfaceless_context
GL_OES_texture_half_float
GL_OES_texture_float
GL_EXT_texture_type_2_10_10_10_REV
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_compression_dxt1
GL_EXT_texture_format_BGRA8888
GL_EXT_texture_compression_s3tc
GL_EXT_read_format_bgra
GL_EXT_multi_draw_arrays
GL_EXT_frag_depth
GL_EXT_discard_framebuffer
GL_EXT_blend_minmax
GL_EXT_multisampled_render_to_texture
GL_EXT_robustness
GL_EXT_texture_sRGB_decode
GL_EXT_texture_rg
GL_EXT_sRGB
GL_VIV_direct_texture
main stats:
max texture size: 8192
max cubemap texture size: 8192
max texture image units: 8
max renderbuffer size: 8064
max combined texture image units: 20
num compressed texture formats: 25
aliased line width range: 1 - 16
aliased point size range: 1 - 128
implementation color read format: RGB
implementation color read type: unsigned byte
max viewport dimensions: 8192 x 8192
subpixel bits: 4
supported compressed texture formats:
0x9270
0x9271
0x9272
0x9273
0x9274
0x9275
0x9276
0x9277
0x9278
0x9279
ETC1_RGB8
PALETTE4_RGBA4_OES
PALETTE4_RGB5_A1_OES
PALETTE4_R5_G6_B5_OES
PALETTE4_RGB8_OES
PALETTE4_RGBA8_OES
PALETTE8_RGBA4_OES
PALETTE8_RGB5_A1_OES
PALETTE8_R5_G6_B5_OES
PALETTE8_RGB8_OES
PALETTE8_RGBA8_OES
COMPRESSED_RGB_S3TC_DXT1_EXT
COMPRESSED_RGBA_S3TC_DXT1_EXT
COMPRESSED_RGBA_S3TC_DXT3_ANGLE
COMPRESSED_RGBA_S3TC_DXT5_ANGLE
shader specific stats:
max vertex attribs: 16
max vertex texture image units: 4
num program binary formats: 0
num shader binary formats: 1
max varying vectors: 11
max vertex uniform vectors: 256
max fragment uniform vectors: 256
shader compiler: yes
supported shader binary formats:
SHADER_BINARY_VIV
OpenVG information:
version string: 1.1
extensions:
VG_KHR_EGL_image
stats:
max scissor rects: 256
max dash count: 256
max kernel size: 7
max separable kernel size: 15
max color ramp stops: 256
max image width: 8192
max image height: 8192
max image pixels: 67108864
max image bytes: 268435456
max gaussian std deviation: 16
image format acceleration:
image format accelerated
sRGBX_8888 no
sRGBA_8888 no
sRGBA_8888_PRE no
sRGB_565 no
sRGBA_5551 no
sRGBA_4444 no
sL_8 no
lRGBX_8888 no
lRGBA_8888 no
lRGBA_8888_PRE no
lL_8 no
A_8 no
BW_1 no
sXRGB_8888 no
sARGB_8888 no
sARGB_8888_PRE no
sARGB_1555 no
sARGB_4444 no
lXRGB_8888 no
lARGB_8888 no
lARGB_8888_PRE no
sBGRX_8888 no
sBGRA_8888 no
sBGRA_8888_PRE no
sBGR_565 no
sBGRA_5551 no
sBGRA_4444 no
lBGRX_8888 no
lBGRA_8888 no
lBGRA_8888_PRE no
sXBGR_8888 no
sABGR_8888 no
sABGR_8888_PRE no
sABGR_1555 no
sABGR_4444 no
lXBGR_8888 no
lABGR_8888 no
lABGR_8888_PRE no
path datatype acceleration:
s8 s16 s32 f
yes yes yes yes
I’ve attached the source codes and the makefile for my project. I am new to Linux and OpenGL. Do we need vivante-fb.so for using OpenGL or not?
link text
