EEPROM - torizon user read access
Hello Toradex team,
I hope you are all doing great!
Hardware:
uname:
  • Linux verdin-imx8mp-14777482 5.15.77-6.3.0+git.ddc6ca4d76ea #1-TorizonCore SMP PREEMPT Thu Jun 29 10:14:22 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
Images tested:
  • torizon-core-docker-verdin-imx8mp-Tezi_6.3.0+build.4.tar (STABLE Release)
Guest OS:
  • macOS (M1 Pro ARM64)
  • Linux ubuntu (VM x86_64)
Issue:
I’m having trouble to setup a udev rules to read the EEPROM only with user permission. The EEPROM is the same as the one on the Verdin board: i2c3@0x57.
I can access it with sudo access as follow:
$ sudo cat /sys/devices/platform/soc@0/30800000.bus/30a50000.i2c/i2c-3/3-0057/eeprom
But I have to give the sudo permission, and I don’t want to for security reason.
I plan to store the serial number of my device on the EEPROM, and I want to be able to use it from my docker container. I have found this link but nobody seems to have a solution… Does anyone ever use this EEPROM and have an idea how I can access it ?
M
Hi @unablesalt !
All good here! I hope you are doing great as well! :smiley:
Thanks for all the detailed information :heart:
Regarding accessing the EEPROM from userspace without using sudo, I searched online for linux eeprom user permission and found this StackOverflow thread: https://stackoverflow.com/questions/29932003/reading-and-writing-eeprom-via-i2c-with-linux
In there, a user redirects to another thread where there is an example of how to set the permissions via udev rule for a device accessible from /sys: https://unix.stackexchange.com/a/202870/293971
I didn’t try it myself but seems to be a good idea.
To perform this change you can use TorizonCore Builder to add your custom udev rule.
Hello @henrique.tx,
Thank you for your response! I hope you are doing great!
The documentation you gave me helped me, and I manage to write a custom rules and I can access it from the user torizon by adding the group i2cdev. Here it is:
DRIVER=="at24", ACTION=="add", RUN+="/bin/chgrp -R i2cdev /sys%p", RUN+="/bin/chmod -R u=rwx,g=rx,o= /sys%p"
DRIVER=="at24", ACTION=="change", RUN+="/bin/chgrp -R i2cdev /sys%p", RUN+="/bin/chmod -R u=rwx,g=rx,o= /sys%p"
Thank you again for your help, I’ll mark this post as solved.
Best,
M
