Ecspi1 chip select is not working on IMX6ULL
Hello all,
i have problem with correct device tree settings for imx6ull module with toradex_5.4-2.3.x-imx kernel branch and own yocto build image based on Toradex Reference Minimal Image.
I have connected two wiznet ethernet chips to ecspi1 and ecspi3.
Ethernet on ecspi3 is working without any problem.
I lost a few days trying to get it up with chip on ecspi1.
Problem is that CS pin (SODIMM 86) is probably not correctly configured by kernel.
Command “gpioinfo” output after boot:
gpiochip2 - 32 lines:
line 26: “SODIMM_86” “spi_imx” input active-high [used]
gpiochip0 - 32 lines:
line 20: “SODIMM_36” “spi_imx” output active-high [used]
ecspi1 CS is configured as “input” why?
ecspi3 CS is configured as “output” correctly.
Very important is when I break in U-Boot and use command “gpio set GPIO3_26 0” (this configure pin to output) and then continue with booting after linux boot ethernet on escpi1 is working correctly.
Can anyone explain me what can be wrong. I assumed that pins should by fully configured by my compiled config dtb. All unnused devices are disabled. No conflict pins I am using it correctly during boot. All others pin uarts, leds etc. are working as i defined.
Maybe there is someting what i am missing …
Thank you for your time and response.
Messages from “cat /sys/kernel/debug/pinctrl/pinctrl-handles”:
device: 2008000.spi current state: default
state: default
type: MUX_GROUP controller 20e0000.iomuxc group: ecspi1-grp (34) function: imx6ull-colibri (0)
type: CONFIGS_PIN controller 20e0000.iomuxc pin MX6UL_PAD_LCD_DATA20 (90)config 000000a0
type: CONFIGS_PIN controller 20e0000.iomuxc pin MX6UL_PAD_LCD_DATA22 (92)config 000000a0
type: CONFIGS_PIN controller 20e0000.iomuxc pin MX6UL_PAD_LCD_DATA23 (93)config 000000a0
type: CONFIGS_PIN controller 20e0000.iomuxc pin MX6UL_PAD_LCD_DATA21 (91)config 000070a0
device: 2010000.spi current state: default
state: default
type: MUX_GROUP controller 20e0000.iomuxc group: ecspi3-grp (36) function: imx6ull-colibri (0)
type: CONFIGS_PIN controller 20e0000.iomuxc pin MX6UL_PAD_UART2_RX_DATA (38)config 000000a0
type: CONFIGS_PIN controller 20e0000.iomuxc pin MX6UL_PAD_UART2_CTS_B (39)config 000000a0
type: CONFIGS_PIN controller 20e0000.iomuxc pin MX6UL_PAD_UART2_RTS_B (40)config 000000a0
type: CONFIGS_PIN controller 20e0000.iomuxc pin MX6UL_PAD_UART2_TX_DATA (37)config 000070a0
Interesting lines from my dtsi configuration files are:
&ecspi1 {
    cs-gpios = <&gpio3 26 GPIO_ACTIVE_LOW>;
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_ecspi1>;
    w5500A: w5500A@0 {
            compatible = "wiznet,w5500";
            pinctrl-0 = <&pinctrl_espi1_int>;
            reg = <0>;
            interrupt-parent = <&gpio1>;
            interrupts = <8 IRQ_TYPE_EDGE_FALLING>;
            spi-max-frequency = <2000000>;
&ecspi3 {
    cs-gpios = <&gpio1 20 GPIO_ACTIVE_LOW>;
    pinctrl-0 = <&pinctrl_ecspi3>;
    w5500B: w5500B@0 {
            pinctrl-0 = <&pinctrl_espi3_int>;
            reg = <0>;
            interrupts = <9 IRQ_TYPE_EDGE_FALLING>;
&iomuxc {
    imx6ull-colibri {
            pinctrl_ecspi1: ecspi1-grp {
                    fsl,pins = <
                            MX6UL_PAD_LCD_DATA20__ECSPI1_SCLK       0x00a0  /* SODIMM 88 */
                            MX6UL_PAD_LCD_DATA22__ECSPI1_MOSI       0x00a0 /* SODIMM 92 */
                            MX6UL_PAD_LCD_DATA23__ECSPI1_MISO       0x00a0 /* SODIMM 90 */
                            MX6UL_PAD_LCD_DATA21__GPIO3_IO26        0x70a0  /* SODIMM 86 */
            pinctrl_espi1_int: espi1int-grp {
                    fsl,pins = <
                            MX6UL_PAD_GPIO1_IO08__GPIO1_IO08        0x13010 /* SODIMM 4 */
            pinctrl_ecspi3: ecspi3-grp {
                    fsl,pins = <
                            MX6UL_PAD_UART2_RX_DATA__ECSPI3_SCLK    0x00a0 /* SODIMM 38 */
                            MX6UL_PAD_UART2_CTS_B__ECSPI3_MOSI      0x00a0 /* SODIMM 32 */
                            MX6UL_PAD_UART2_RTS_B__ECSPI3_MISO      0x00a0 /* SODIMM 34 */
                            MX6UL_PAD_UART2_TX_DATA__GPIO1_IO20     0x70a0  /* SODIMM 36 */
            pinctrl_espi3_int: espi3int-grp {
                    fsl,pins = <
                            MX6UL_PAD_GPIO1_IO09__GPIO1_IO09        0x13010 /* SODIMM 2 */
Dear @milsrak,
Sorry for the time that we took to answer you. Can you please confirm the following information before we can go into further detail?
  1. Which exact Module and Version of Colibri iMX6ULL are you using?
  2. Which Carrier Board and Version are you using?
  3. Which BSP Version did you based yourself on to make your custom image? 5.6? 5.5?
  4. Does the same behavior also happens on an image from Toradex without any customization? If the answer is no, can you please share with us the exact steps you followed to customize your image?
Thanks a lot.
Guilherme
Compared to other modules, spidev, mcp2518, input and output on CS shouldn’t surprise you. I don’t know purpose of this direction switching, but other fully functional drivers behave the same.
Dear @milsrak,
Do you have any updates on that topic? Have you been able to solve your issue?
