First downloaded the virtual box and imported ecos as given in “eCos® RTOS on the Cortex M4 of a Colibri VF61” . Then on doing further processes as per the documentation given by “https://docs.toradex.com/102017-ecos-colibri-vf61-vybrid.pdf” during the step [2.2 Source code] for downloading the Colibri VF61 eCos source it seems to have an error. Error shows that the site “https://github.com/mgielda/ecos-colibri-vf61.git” is removed. So anyone please give the location of the newly created one. The error shown is attached below:
Hi sreemadav,
Do you have a new Project? If yes, then you should use FreeRTOS, which is supported by Toradex.
Hi jaski.tx,
Okay. But what about eCos. Is there any disadvantage in using it?
Hi jaski.tx,
In FreeRTOS while running a firmware on cortex m4 from u-boot using m4boot in Colibri VF61 it seems to have an error while doing the step “$ mkimage -f vybridm4.its vybridm4-freertos.itb”. The error is attached below. Can anyone please find me the solution for this. I followed the steps from the site “High performance, low power Embedded Computing Systems | Toradex Developer Center”
there is no disadvantage, but as i said for freeRTOS, you will get InHouse Support.
