in 10% of system startups I noticed an echo in the image
the echo can already be seen in the kernel splash screen stage
and all the time until restart
My platform iris 2.0 , imx8x + lvds display
Have you tried another cable or/and monitor?
I tested different LCD panel on LVDS and test another monitor !
Images in my first post are from LCD on LVDS
IRIS 2.0 has VGA output on DVI , now in attachmend I send image from DVI-VGA out image when I have “echo” on LVDS
the picture on VGA is more broken !
dmesg_ok.txt (30.9 KB)
dmesg_echo.txt (30.8 KB)
Hi @MariusM ,
Could you please share more information about you setup?
/boot/overlays.txt
Looks like LCD parametres like pixel clock, sync signal polarity etc doesn’t exactly match your display spec.
Colibri iMX8 PN: 00381003 Colibri iMX8 QuadXPlus 2GB Wi-Fi / Bluetooth IT
Carrier board: PN: 01352000 Iris Carrier Board V2.0A
BSP version: TDX Wayland with XWayland 5.6.0-devel-20220201194419+build.0 (dunfell)
Kernel: Linux colibri-imx8x-06948283 5.4.161-5.6.0-devel+git.e395d949e46b
Application: Qt + 3D in OpenGLES
Normal mode: Qt application display on screen connected over LVDS to IRIS
Display AA070MC01 Mitsubishi
fdt_overlays=colibri-imx8x_parallel-rgb-lvds_overlay.dtbo colibri-imx8x_atmel-mxt-connector_overlay.dtbo display-edt7_overlay.dtbo
Hi @MariusM !
Comparing the datasheet and the overlay that you are using (display-edt7_overlay.dtbo
), seems like they are not compatible.
Let’s take a look at the timing diagram of your display
From this, seems like all the blanking time (front porch + back porch + sync) must be either before or after the active time for both vertical and horizontal time.
And the overlay for Toradex’s EDT7 display has blanking time for both before and after active time.
Reference: device-trees/display-edt7_overlay.dts at fdac8d2e0269f6d735d5b69d7975bd2c23a81438 · toradex/device-trees · GitHub
Could you please try both settings:
Thanks for the suggestions.
I am watching the screen!
Echo does not appear!
Hi @MariusM !
Great that it worked for you!
Could you please share the working device tree, so it can serve as a guide for others?
I’m still investigating the problem!
