I’m trying to connect to a freshly installed Torizon Easy Installer using VNC because no display is connected at the moment. Both 192.168.11.1 (USB RNDIS) and the local IP in my network result in “connection refused”. I can ping both IPs successfully. Must I do something extra to enable the VNC server? Using Torizon Easy Installer v2.0b7 on a Verdin 1.1 development board with a Verdin V1.1A
First time reinstalling Easy Installer seemed to work according to ubuntu terminal. No VNC was available and a portscan showed the open ports from our project. Reinstalled Easy Installer again, and now the port scanner is showing
We just tried to reproduce your issue using Easy Installer 2.0b7, but it is working from our side.
About the “Too big desktop name length…”, could you try to modify the settings regarding the scaling of the image? Maybe something like “no auto” or “fix setting” could help you.
On Remmina, maybe go to Preferences > Appearance > Default view and try different settings.
Hello, I 'm facing the same behaviour.
I enter into recovery mode, then I load latest version Verdin-iMX8MM_ToradexEasyInstaller_5.5.0+build.6 from the host, and after it boots (I see TEZI log output console) I cannot connect using VNC. After a while it throws timeout.
Doing the same but loading a previous version (Verdin-iMX8MM_ToradexEasyInstaller_5.4.0+build.4) works correctly and allows me to connect using the same VNC connection.
Alejandro
Verdin iMX8MM V1.1A
Verdin Development Board V1.1A
I used in both cases 192.168.0.20
It doesn’t matter at all to me by now, I’ve just had that problem and I solved it by using a previous version. I’m giving the information because maybe there is something wrong in the newer version, so it will be present in newer ones. Altough I’m not sure if it is a problem or a misconfiguration.
Just for information we see this issue pretty commonly as well. Some versions of EasyInstaller work and some don’t. 5.4 build 4 is the last working for us.
Ed
I have just tested latest version: TEZI v5.6.0b9 and usb0 adapter is available again, and I was also able to connect through VNC properly (using 192.168.0.20:5900 in my case).
