Hardware: Colibri iMX6DL 512MB IT V1.1Y, we use our own carrier board
From time to time we fail to install our WindowsCE and application via Toradex EasyInstaller script from USB stick. The colibri module resulting state is the EasyInstaller does no more start up so we cannot re-try to install from USB stick. In bootloader output we see several BOOTP broadcast tokens.
How could one force the Colibri into this state? Our script works 99% of the time, could this be a timing problem somewhere?
We can recover the Colibris by loading EasyInstaller again = factory default.
Bootloader output (this time from Toradex Colibri Evaluation Board V3.2B):
Industrial temperature grade DDR3 timings, 64bit bus width.
Trying to boot from MMC1
U-Boot 2020.07-5.3.0+git.68f97c8d17f0 (Jul 06 2021 - 15:50:15 +0000)
CPU: Freescale i.MX6DL rev1.4 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 45C
Reset cause: POR
DRAM: 512 MiB
PMIC: device id: 0x10, revision id: 0x21, programmed
MMC: FSL_SDHC: 1, FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6 DualLite 512MB IT V1.1Y, Serial# 11066458
Net: eth0: ethernet@2188000
MMC: no card present
switch to partitions #0, OK
** Unrecognized filesystem type **
starting USB...
Bus usb@2184000: USB EHCI 1.00
Bus usb@2184200: USB EHCI 1.00
scanning bus usb@1 USB Device(s) found
scanning bus usb@2184200 for devices... 4 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
ethernet@2188000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Could not initialize PHY ethernet@2188000
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
## Error inserting "stdout" variable, errno=22
## Error inserting "stdin" variable, errno=22
Colibri iMX6 TEZI #
Bootloader environment:
Colibri iMX6 TEZI # printenv
arch=arm
baudrate=115200
board=colibri_imx6
board_name=colibri_imx6
board_rev=0112
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr ${fdtcontroladdr};fi;load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_file=zImage
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot-tezi.scr
boot_scripts=boot-tezi.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=mmc1 mmc0 usb0 dhcp
bootcmd=run distro_bootcmd; usb start ; setenv stdout serial,vidconsole; setenv stdin serial,usbkbd
bootcmd_dhcp=setenv devtype dhcp; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_mmc0=devnum=0; run mmc_boot
bootcmd_mmc1=devnum=1; run mmc_boot
bootcmd_usb0=devnum=0; run usb_boot
bootcount=1
bootdelay=1
bootm_size=0x10000000
console=ttymxc0
cpu=armv7
defargs=enable_wait_mode=off galcore.contiguousSize=50331648
devtype=dhcp
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
ethact=ethernet@2188000
ethaddr=00:14:2d:a8:dc:5a
fdt_addr_r=0x12100000
fdt_file=imx6dl-colibri-eval-v3.dtb
fdt_fixup=;
fdtcontroladdr=2df69610
fdtfile=imx6dl-colibri-eval-v3.dtb
ipaddr=192.168.10.2
kernel_addr_r=0x11000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
loadaddr=0x12000000
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
netmask=255.255.255.0
pxefile_addr_r=0x17100000
ramdisk_addr_r=0x12200000
rootpath=/srv/nfs
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done; setenv devplist
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable media binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x17000000
serial#=11066458
serverip=192.168.10.1
set_blkcnt=setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200
setethupdate=if env exists ethaddr; then; else setenv ethaddr 00:14:2d:00:00:00; fi; tftpboot ${loadaddr} flash_eth.img && source ${loadaddr}
setsdupdate=setenv interface mmc; setenv drive 1; mmc rescan; load ${interface} ${drive}:1 ${loadaddr} flash_blk.img && source ${loadaddr}
setup=setenv setupargs fec_mac=${ethaddr} consoleblank=0 no_console_suspend=1 console=tty1 console=${console},${baudrate}n8
setupdate=run setsdupdate || run setusbupdate || run setethupdate
setusbupdate=usb start && setenv interface usb; setenv drive 0; load ${interface} ${drive}:1 ${loadaddr} flash_blk.img && source ${loadaddr}
soc=mx6
splashimage=0x12000000
splashpos=m,m
uboot_blk=8a
uboot_hwpart=1
uboot_spl_blk=2
update_spl=run set_blkcnt && mmc dev 0 ${uboot_hwpart} && mmc write ${loadaddr} ${uboot_spl_blk} ${blkcnt}
update_uboot=run set_blkcnt && mmc dev 0 ${uboot_hwpart} && mmc write ${loadaddr} ${uboot_blk} ${blkcnt}
usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
vendor=toradex
ver=U-Boot 2020.07-5.3.0+git.68f97c8d17f0 (Jul 06 2021 - 15:50:15 +0000)
vidargs=fbmem=8M
Environment size: 5195/8188 bytes
Colibri iMX6 TEZI #
Our EasyInstaller script image.json:
"config_format": 1,
"autoinstall": true,
"name": "bootloader and image",
"description": "No file encryption",
"icon": "SH_ICON.png",
"version": "2.1.21097.0",
"release_date": "2021-04-07",
"wrapup_script": "wrapup.sh",
"supported_product_ids": [
"0015",
"0017"
"blockdevs": [
"erase": true,
"name": "mmcblk0",
"content": {
"filesystem_type": "raw",
"rawfiles": [
"filename": "Backup.i6r",
"dd_options": "seek=2",
"size": 8
"filename": "cleanreg.bin",
"dd_options": "seek=16386"
"filename": "EasyInstallerSplash.tss",
"dd_options": "seek=32770",
"size": 1
"filename": "nk.nbx",
"dd_options": "seek=40962",
"size": 28
"partitions": [
"partition_size_nominal": 256,
"want_maximised": true,
"partition_type": "07",
"offset_in_sectors": 196608
"erase": true,
"name": "mmcblk0boot0",
"content": {
"rawfiles": [
"filename": "SPL-colibri",
"filename": "eboot.spl",
"dd_options": "seek=138"
wrapup.sh:
#!/bin/sh
# (c) Toradex AG 2016
# Apalis/Colibri iMX6 in-field hardware update script
# One-time configurations (non-reversible!):
# - Fuse SoC to use eMMC Fast Boot mode
# - Enable eMMC H/W reset capabilities
# Required configurations
# - Configure Boot Bus mode (due to eMMC Fast Boot mode above)
# Other configurations
# - Boot from eMMC boot partition (must run as wrapup script)
PRODUCT_ID=$1
BOARD_REV=$2
SERIAL=$3
IMAGE_FOLDER=$4
error_exit () {
echo "$1" 1>&2
exit 1
# Do a basic validation that we do this on one of our modules
case $PRODUCT_ID in
0027|0028|0029|0035) ;;
0014|0015|0016|0017) ;;
*) error_exit "This script is meant to be run on a Apalis/Colibri iMX6. Aborting...";
esac
# Fuse SoC's BOOT_CFG to enable eMMC Fast Boot mode, if necsary
# WARNING: Fusing is a one-time operation, do not change values
# here unless you are absolutely sure what your are doing.
BOOT_CFG=0x5072
if [ ! -f /sys/fsl_otp/HW_OCOTP_CFG4 ]; then
echo "Fusing not supported."
elif grep -q ${BOOT_CFG} /sys/fsl_otp/HW_OCOTP_CFG4; then
echo "No new value for BOOT_CFG required."
else
echo ${BOOT_CFG} > /sys/fsl_otp/HW_OCOTP_CFG4
if [ "$?" != "0" ]; then
error_exit "Writing fuse BOOT_CFG failed! Aborting..."
fi
echo "Fuse BOOT_CFG updated to ${BOOT_CFG}."
fi
# eMMC configurations
MMCDEV=/dev/mmcblk0
# Enable eMMC H/W Reset feature. This need to be executed before the other
# eMMC settings, it seems that this command resets all settings.
# Since this is a one-time operation, it will fail the second time. Ignore
# errors and redirect stderr to stdout.
mmc hwreset enable ${MMCDEV} 2>&1
if [ "$?" == "0" ]; then
echo "H/W Reset permanently enabled on ${MMCDEV}"
fi
# Set boot bus mode
if ! mmc bootbus set single_hs x1 x8 ${MMCDEV}; then
error_exit "Setting boot bus mode failed"
fi
# Enable eMMC boot partition 1 (mmcblkXboot0) and boot ack
# Make sure everything hit the eMMC when execute this command. Otherwise
# the eMMC will reset the configuration.
sync
if ! mmc bootpart enable 1 1 ${MMCDEV}; then
error_exit "Setting bootpart failed"
fi
mmc extcsd read ${MMCDEV} | grep -e BOOT_BUS_CONDITIONS -e PARTITION_CONFIG -e RST_N_FUNCTION
echo "Apalis/Colibri iMX6 in-field hardware update script ended successfully."
#CTC special: write config block and reboot to install container from autorun
IMAGE_FOLDER=$4
OFFSET=$(($(($(cat /sys/block/mmcblk0boot0/size)-127))*32))
echo "Writing config block to boot partition"
dd if=${IMAGE_FOLDER}/Backup.cfg of=/dev/mmcblk0boot0 bs=16 skip=1 count=4032 seek=$OFFSET
sleep 10
reboot -f
exit 0
