As I noticed that Easy Installer listens two TCP ports 5900 for VNC and 8080 for Toradex Easy Installer 5.6.0-devel HTTP API . What are the capabilities of HTTP APIs? Is it possible to follow the whole flashing process through HTTP APIs by sending commands remotely like erase, flash image xx in the usb memory and get the result of the operation?
Currently, the API is only intended for internal use and is not publicly documented. It can be changed without notice. So if you develop something using it, your solution might simply break on upcoming versions. If you want to use it, you are on your own.
But, if you can, please share with us your use-case/needs/requirements. We can capture it internally and it is possible that in the future your use-case helps to make this API an official tool for Easy Installer
I was wondering if anything has moved on regarding this?
We too would like to have the option to automate a query to get the status from the Easy Installer.
Many thanks,
James
Hi @henrique.tx ,
Thanks a lot for the reply.
I understand that there is no support offered for these tools, but is there any information available showing what functionality is currently available? I fully accept that the next build may not have the same functions, or the operation of these functions may change, but this would really help us with the internal automation processes.
James
You can download and load the latest version of Toradex Easy Installer (which is not necessarily the same version that is shipped with the SoMs) and use the tezictl --help command to check the available commands.
/ # tezictl --help-all
Usage: tezictl [options] <command>
Toradex Easy Installer command line tool
Options:
-h, --help Displays help on commandline options.
--help-all Displays help including Qt specific options.
-v, --version Displays version information.
--accept-all-licenses Accept all license dialogs (license & release
notes), only available for image-install command.
--qmljsdebugger <value> Activates the QML/JS debugger with a specified port.
The value must be of format port:1234[,block].
"block" makes the application wait for a connection.
Arguments:
<command> image-list
image-install
feed-list
feed-add
status
First try image-list
/ # tezictl image-list
Currently available images:
[0] xhcd - GPR Array image with development tools
Version: 3.1.14 (2022-04-21)
URI:
[1] GPR Array image with development tools
Version: 3.1.16 (2023-03-14)
URI: sdcard:/gprarr-image-xbf
[2] Toradex Embedded Linux Reference Multimedia Image
Version: 5.7.2-devel-20230326+build.774 (2023-03-26)
URI:
[3] prototype2
Version: 3.1.16 (2023-01-31)
URI:
[4] scs7_with_avalon-dma civetweb 1.15 - all Edimax - libsyscommon 1.36
Version: 3.1.16 (2023-01-25)
URI:
[5] AlexGo-Avalon-Driver-Impelemtation4
Version: 3.1.16 (2022-12-20)
URI:
[6] scs7 - civetweb 1.15 - all Edimax - libsyscommon 1.36 - Altera DMA driver added
Version: 3.1.16 (2022-12-14)
URI:
[7] GPR Array image with development tools
Version: 3.1.16 (2022-08-31)
URI:
[8] scs4 - GPR Array image with development tools
Version: 3.1.16 (2022-08-19)
URI:
[9] scs3 - GPR Array image with development tools
Version: 3.1.16 (2022-08-08)
URI:
[10] full-gprarr-image-dev-yocto-eagle-edimax - GPR Array image with development tools
Version: 3.1.16 (2022-08-04)
URI:
[11] Toradex Easy Installer
Version: 5.6.0-devel-20220309+build.296 (2022-03-09)
URI:
[12] TorizonCore with evaluation containers
Version: 5.7.2+build.20.modified.container (2023-03-29)
URI: http://tezi.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/dunfell-5.x.y/release/20/verdin-imx8mp/torizon/torizon-core-docker-evaluation/teziimage/
[13] TorizonCore with evaluation containers
Version: 6.1.0+build.1.modified.container (2023-01-16)
URI: http://tezi.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/kirkstone-6.x.y/release/1/verdin-imx8mp/torizon/torizon-core-docker-evaluation/teziimage/
[14] Toradex Easy Installer
Version: 5.7.2+build.14 (2023-02-22)
URI: http://tezi.toradex.com/artifactory/tezi-oe-prod-frankfurt/dunfell-5.x.y/release/14/verdin-imx8mp/tezi/tezi-run/teziimage/
[15] Toradex Embedded Linux Reference Multimedia Image
Version: 6.2.0+build.6 (2023-04-03)
URI: http://tezi.toradex.com/artifactory/tdxref-oe-prod-frankfurt/kirkstone-6.x.y/release/6/verdin-imx8mp/tdx-xwayland/tdx-reference-multimedia-image/teziimage/
[16] Toradex Embedded Linux Reference Multimedia Image (UPSTREAM)
URI: http://tezi.toradex.com/artifactory/tdxref-oe-prod-frankfurt/kirkstone-6.x.y/release/6/verdin-imx8mp/tdx-xwayland-upstream/tdx-reference-multimedia-image/teziimage/
[17] Toradex Embedded Linux Reference Minimal Image (UPSTREAM)
URI: http://tezi.toradex.com/artifactory/tdxref-oe-prod-frankfurt/kirkstone-6.x.y/release/6/verdin-imx8mp/tdx-xwayland-upstream/tdx-reference-minimal-image/teziimage/
[18] Toradex Embedded Linux Reference Minimal Image
URI: http://tezi.toradex.com/artifactory/tdxref-oe-prod-frankfurt/kirkstone-6.x.y/release/6/verdin-imx8mp/tdx-xwayland/tdx-reference-minimal-image/teziimage/
[19] Toradex Embedded Linux Reference Multimedia Image
Version: 5.7.2+build.21 (2023-02-22)
URI: http://tezi.toradex.com/artifactory/tdxref-oe-prod-frankfurt/dunfell-5.x.y/release/21/verdin-imx8mp/tdx-xwayland/tdx-reference-multimedia-image/teziimage/
[20] Toradex Embedded Linux Reference Minimal Image
URI: http://tezi.toradex.com/artifactory/tdxref-oe-prod-frankfurt/dunfell-5.x.y/release/21/verdin-imx8mp/tdx-xwayland/tdx-reference-minimal-image/teziimage/
[21] Maivin - Modular full-stack AI Vision System - TorizonCore
Version: auzone-0.1-torizoncore5.5.0-devel-202112 (2021-12-02)
URI: http://tezi.toradex.com/artifactory/legacy-oe-3rdpartyprod-frankfurt/Verdin-imx8mp_Maivin-tezi-image_auzone-0.1-torizoncore5.5.0-devel-202112/teziimage/Verdin-imx8mp_Maivin-tezi-image_auzone-0.1-torizoncore5.5.0-devel-202112/
Checking status:
/ # tezictl status
idle
Then try to load image [2] Toradex Embedded Linux Reference Multimedia Image:
/ # tezictl image-install 2 --accept-all-licenses
Error: Timeout reached, aborting...
/ # tezictl status
installing
/ # tezictl status
installing
/ # tezictl status
installing
/ # tezictl status
installing
/ # tezictl status
installing
/ # tezictl status
installed
/ # tezictl status
installed
Not bad, I need to spend more time on it
Thank you.
