I am having problems using the Toradex Easy Installer.
I am using this version: Apalis-iMX6_ToradexEasyInstaller_1.5-20180507
U-Boot: U-Boot 2016.11-1.1.0+g51b53b4 (Sep 06 2017 - 15:19:08 -0700)
The install is performed on a native install of Ubuntu Mate (not a VM):
Linux xxxxx 4.15.0-22-generic #24-Ubuntu SMP Wed May 16 12:15:17 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04 LTS
Release: 18.04
Codename: bionic
I followed the instructions from here:
U-Boot console output:
CPU: Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 2 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
Using default environment
In: serial_mxc
Out: serial_mxc
Err: serial_mxc
Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 05170634
Net: using PHY at 7
FEC [PRIME]
Apalis iMX6 # bmode usb
resetting ...
Industrial temperature grade DDR3 timings.
Trying to boot from USB SDP
g_dnl_register: failed!, error: -19
SDP: initialize...
SDP: handle requests...
Installer output:
linbox@xxxxxx:~/Desktop/Apalis-iMX6_ToradexEasyInstaller_1.5-20180507$ sudo ./recovery-linux.sh -d
Downloading Toradex Easy Installer...
config file <./recovery//imx_usb.conf>
vid=0x15a2 pid=0x0054 file_name=mx6_usb_rom.conf
-> vid=0x1b67 pid=0x4fff file_name=mx6_usb_sdp_spl.conf
-> vid=0x1b67 pid=0x4000 file_name=mx6_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0061 file_name=mx6_usb_rom.conf
vid=0x15a2 pid=0x0076 file_name=mx7_usb_rom.conf
-> vid=0x1b67 pid=0x4000 file_name=mx7_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0080 file_name=mx6ull_usb_rom.conf
-> vid=0x1b67 pid=0x4000 file_name=mx6ull_usb_sdp_uboot.conf
config file <./recovery//mx6_usb_rom.conf>
parse ./recovery//mx6_usb_rom.conf
Trying to open device vid=0x15a2 pid=0x0054
Interface 0 claimed
HAB security state: development mode (0x56787856)
== work item
filename SPL
load_size 0 bytes
load_addr 0x13f00000
dcd 0
clear_dcd 0
plug 0
jump_mode 2
jump_addr 0x00000000
== end work item
loading binary file(SPL) to 00907400, skip=0, fsize=bc00 type=aa
<<<48128, 48128 bytes>>>
succeeded (status 0x88888888)
jumping to 0x00907400
config file <./recovery//mx6_usb_sdp_spl.conf>
parse ./recovery//mx6_usb_sdp_spl.conf
Trying to open device vid=0x1b67 pid=0x4fff.........................
Could not open device vid=0x1b67 pid=0x4fff
Downloading Toradex Easy Installer failed...
I have looked at other posts with similar title, but there is little information to help me diagnose and fix the problem. Any hints would be appreciated.
