Is there a way to have a setting in the image.json file, or somewhere else, to allow the flash to be erased on the device prior to the auto-install feature loading the image?
When running a unit in recovery mode and you load Easy Installer into memory, it would be good to have a method to purge the flash with an autorun image. Or some other scripted means.
thanks,
–Eric
