we have a production programming setup for the imx6DL and running WCE2013 in place.
Now we face the following problem: With easy-installer 1.8 (and I think 2.x, too) the progress could be
displayed on our lcd-display w/o any problems
As of easy-installer 5.x the default configuration for displays must have been changed, as our lcd-display remains black during installation.
I have tried to set the configblock in the wrapup.sh script with our display-settings. It is apparently installed, because after a power-cycle the display works perfectly.
Currently we do a ‘reboot -f’ at the end of the wrapup.sh script. This apparently does not boot using the configblock, the screen remains black.
Any suggesstions how to apply our lcd-display settings to the toradex easy-installer? Preferably in the prepare.sh script, so the worker can see the installation of the BSP already.
Kind Regards
Thomas
Hi @t_achmann !
We have this Custom Boot | Toradex Developer Center article that might help you. Could you give it a try?
Also, which kind of interface does your LCD display uses?
And could you share what exactly have you tried on wrapup.sh
Hi Henrique,
customizing the toradex easy-installer does not help, since our manufacturer buys the imx6-modules directly from Toradex.
Our display uses the RGB interface. (I’m attaching its data sheet)
Please find the wrapup script attached
Kind Regards
Thomas
Display Datasheet: SCX0700C48GGU1E.pdf (1.5 MB)
wrapup.sh (2.8 KB)
Hi @t_achmann !
Which exact module and carrier board versions are you using?
sorry for the late reply.
Carrieboard is a custom design, but it follows toradex’s reference design.
The module we use is a Toradex Colibri IMX6DL 512MB V1.1A
Well our display worked fine with the “old” easy-installers…
kind regards
Thomas
Hi @t_achmann !
Could you please share the full log from Tezi? Both output from dmesg
(the boot log) and the tezi.log
(should be in /var/volatile
If you can’t easily find tezi.log
, please run a search to find it:
$ find -name / "*tezi.log*"
