Easy Installer access Ubuntu 22.04 RNDIS USB problem
Hello everyone.
I’m trying to install the Easy installer in the Apalis iMXD6( lxora carrier board ) and open the remote desktop using the VNC, as described here(Toradex Easy Installer Documentation Overview | Toradex Developer Center). I’m using ubuntu 22.04 LTS and I installed the Vinagre VNC client. I followed all the steps provided, but when I tried to access the board using Vinagre(192.168.11.1) I received the message saying that the “connection to host 192.168.11.1 was closed”.
Here are the output messagem from the dmesg | grep usb command:
andre@andre-Inspiron-3583:~$ sudo dmesg | grep usb
[ 0.243487] usbcore: registered new interface driver usbfs
[ 0.243487] usbcore: registered new interface driver hub
[ 0.243487] usbcore: registered new device driver usb
[ 0.860208] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 0.860211] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.860213] usb usb1: Product: xHCI Host Controller
[ 0.860215] usb usb1: Manufacturer: Linux 5.19.0-46-generic xhci-hcd
[ 0.860216] usb usb1: SerialNumber: 0000:00:14.0
[ 0.870496] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.19
[ 0.870499] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.870500] usb usb2: Product: xHCI Host Controller
[ 0.870502] usb usb2: Manufacturer: Linux 5.19.0-46-generic xhci-hcd
[ 0.870503] usb usb2: SerialNumber: 0000:00:14.0
[ 0.873108] usb: port power management may be unreliable
[ 1.127400] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.277055] usb 1-1: New USB device found, idVendor=1b67, idProduct=401d, bcdDevice= 0.01
[ 1.277066] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.277071] usb 1-1: Product: Apalis iMX6 Dual 512MB
[ 1.277075] usb 1-1: Manufacturer: Toradex
[ 1.277078] usb 1-1: SerialNumber: 05164178
[ 1.407399] usb 1-5: new full-speed USB device number 3 using xhci_hcd
[ 1.847493] usb 1-5: New USB device found, idVendor=27c6, idProduct=5301, bcdDevice= 1.00
[ 1.847496] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.847498] usb 1-5: Product: Goodix Fingerprint Device
[ 1.847499] usb 1-5: Manufacturer: HTMicroelectronics
[ 1.847499] usb 1-5: SerialNumber: HTK32
[ 2.103561] usb 1-6: new high-speed USB device number 4 using xhci_hcd
[ 3.302742] usb 1-6: New USB device found, idVendor=0c45, idProduct=671e, bcdDevice=85.02
[ 3.302746] usb 1-6: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 3.302747] usb 1-6: Product: Integrated_Webcam_HD
[ 3.302748] usb 1-6: Manufacturer: CN0G4JK9LOG0091FD1DZA01
[ 3.431555] usb 1-10: new full-speed USB device number 5 using xhci_hcd
[ 3.581574] usb 1-10: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[ 3.581588] usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.599019] usbcore: registered new interface driver cdc_ether
[ 3.602751] rndis_host 1-1:1.0 eth0: register ‘rndis_host’ at usb-0000:00:14.0-1, RNDIS device, 00:14:2d:ff:ff:fe
[ 3.602774] usbcore: registered new interface driver rndis_host
[ 4.531252] usbcore: registered new interface driver rndis_wlan
[ 4.578060] usbcore: registered new interface driver btusb
[ 4.595180] usb 1-6: Found UVC 1.00 device Integrated_Webcam_HD (0c45:671e)
[ 4.640673] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input13
[ 4.643454] usb 1-10: USB disconnect, device number 5
[ 4.668400] usbcore: registered new interface driver cdc_acm
[ 4.670411] usbcore: registered new interface driver uvcvideo
[ 5.055302] usb 1-10: new full-speed USB device number 6 using xhci_hcd
[ 5.268504] usb 1-10: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[ 5.268508] usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1057.398921] usb 1-3: new high-speed USB device number 7 using xhci_hcd
[ 1057.561647] usb 1-3: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= c.00
[ 1057.561662] usb 1-3: New USB device strings: Mfr=7, Product=8, SerialNumber=9
[ 1057.561668] usb 1-3: Product: SAMSUNG_Android
[ 1057.561673] usb 1-3: Manufacturer: SAMSUNG
[ 1057.561678] usb 1-3: SerialNumber: RX8R40HNCZT
[ 1060.591870] usb 1-3: USB disconnect, device number 7
[ 1061.086855] usb 1-3: new high-speed USB device number 8 using xhci_hcd
[ 1061.239373] usb 1-3: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= c.00
[ 1061.239388] usb 1-3: New USB device strings: Mfr=7, Product=8, SerialNumber=9
[ 1061.239394] usb 1-3: Product: SAMSUNG_Android
[ 1061.239399] usb 1-3: Manufacturer: SAMSUNG
[ 1061.239403] usb 1-3: SerialNumber: RX8R40HNCZT
[ 2027.064061] usb 1-1: USB disconnect, device number 2
[ 2027.064348] rndis_host 1-1:1.0 enx00142dfffffe: unregister ‘rndis_host’ usb-0000:00:14.0-1, RNDIS device
[ 2029.102968] usb 1-1: new high-speed USB device number 9 using xhci_hcd
[ 2029.253097] usb 1-1: New USB device found, idVendor=1b67, idProduct=401d, bcdDevice= 0.01
[ 2029.253101] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2029.253102] usb 1-1: Product: Apalis iMX6 Dual 512MB
[ 2029.253104] usb 1-1: Manufacturer: Toradex
[ 2029.253105] usb 1-1: SerialNumber: 05164178
[ 2029.258492] rndis_host 1-1:1.0 eth0: register ‘rndis_host’ at usb-0000:00:14.0-1, RNDIS device, 00:14:2d:ff:ff:fe
[ 2040.882535] usb 1-3: USB disconnect, device number 8
Could someone please help me?
Hi @andrehpd-eld ,
Do you have access to the serial interface? If yes, can you please check if the module got the IP 192.168.11.1 before trying to connect using VNC? You can check this by running the command ifconfig.
Daniel Morais
Hi @daniel_m.tx .
Sorry for the long delay in the answer. We found that the network interface wasn’t being properly configured in ubuntu. After activating it, I was able to connect throught VNC in ip 192.168.11.1.
André Dantas
