The EasyInstaller starts flashing the image but freezes around %1. The mouse and the marketing images are responsive (it’s not a kernel carsh), but the progress bar doesn’t advance at all.
I’ve tried both MMC and USB flash disk as carrier for the image, but it didn’t make any difference.
I have uploaded some of the logs of easy installer that could help to debug this issue. Note the CPU seems to be idle : Download - Toradex File Sharing Platform
What you are seeing is probably the following known issue. Either plug in Ethernet/Internet to have the date/time automatically be set or manually do so. The upcoming version 1.5 will have this fixed.
Hi Marcel, my image freezes around 3%. When I set clock manually with “date -s 2018-04-10” my image freezes around 93%. Do you have any advice for me? Regards Davide
