E-con systems AR0521 camera for BSP 7
Can we use “GitHub - toradex/meta-toradex-econ” patches to get AR0521 working with the latest kernel branch : toradex_6.6-2.0.x-imx
Hello!
The ‘meta-toradex-econ’ GitHub repository indeed contains patches and meta-layers intended to support e-con Systems cameras, such as the AR0521, on Toradex hardware. However, the compatibility of these patches with the latest kernel branch ‘toradex_6.6-2.0.x-imx’ isn’t explicitly documented.
To determine if these patches can be used with the ‘toradex_6.6-2.0.x-imx’ kernel branch, you can follow these steps:
  1. Review Repository Documentation: Check the documentation and commit history in the ‘meta-toradex-econ’ repository for any notes or updates regarding compatibility with the ‘toradex_6.6-2.0.x-imx’ branch.
  2. Test the Patches: If the documentation does not provide a definitive answer, consider testing the patches with the ‘toradex_6.6-2.0.x-imx’ branch. This involves applying the patches to your build environment and verifying if the camera operates as expected.
  3. Examine Release Notes: Look at the release notes for the ‘toradex_6.6-2.0.x-imx’ branch to identify any changes that might impact camera support or patch compatibility.
By following these steps, you can better assess whether the patches from ‘meta-toradex-econ’ will work with your desired kernel branch.
Mxc_lcdif driver add to kernel 6.4.0 for colibri imx6.
I need to do changes in the toradex_defconfig but it is removed in the latest linux-toradex.
from where I will get the defconfig file for latest BSP
Hello @artirajput ,
Currently, there are no plans to support the e-con AR0521 camera on BSP 7 and higher.
For testing purposes, we recommend using the CSI Camera OV5640, which counts with mainline support and makes testing much easier for developers.
Marcio
