Hello, I’m trying to get working iMX6 Apalis module with 2 different displays (LVDS as main display and HDMI as optional display) in dual mode (not mirroring!) with Qt5 and EGLFS.
I’ve configured kernel and device tree, everything is working very well but only if HDMI cable is connected at bootup.
Here is the initialization string:
vidargs=video=mxcfb0:dev=ldb,1024x600@60,if=RGB18,bpp=18 video2=mxcfb1:hdmi,1024x768M@60,if=RGB24 video=mxcfb2:off video=mxcfb3:off ldb=dul1 fbmem=32M
And device tree for LVDS/HDMI:
mxcfb1: fb@0 {
compatible = "fsl,mxc_sdc_fb";
disp_dev = "ldb";
interface_pix_fmt = "RGB24";
default_bpp = <32>;
int_clk = <0>;
late_init = <0>;
status = "disabled";
mxcfb2: fb@1 {
disp_dev = "hdmi";
mode_str ="1920x1080M@60";
default_bpp = <16>;
int_clk = <0>;
late_init = <0>;
&ldb {
ipu_id = <0>;
disp_id = <1>;
lvds-channel@0 {
reg = <0>;
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
crtc = "ipu2-di1";
primary;
display-timings {
native-mode = <&timing_lvds>;
timing_lvds: 1024x600 {
clock-frequency = <51200000>;
hactive = <1024>;
vactive = <600>;
hback-porch = <110>;
hfront-porch = <110>;
vback-porch = <15>;
vfront-porch = <15>;
hsync-len = <100>;
vsync-len = <5>;
de-active = <1>;
pixelclk-active = <0>;
If the HDMI cable was not connected and is connected afterwards the image on the display is corrupted. It looks like the frequency of the signal was not properly initialized.
But kernel log shows that the same settings were applied for both modes:
With cable:
mxc_sdc_fb fb@1: 1280x1024 h_sync,r,l: 112,48,248 v_sync,l,u: 3,1,38 pixclock=108003000 Hz
Without cable:
mxc_sdc_fb fb@1: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
... Cable is connected here ...
mxc_hdmi 20e0000.hdmi_video: Read EDID again
mxc_sdc_fb fb@1: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25175000 Hz
What am I doing wrong? I have tried to reinitialize the HDMI display writing 1 to blank property in the fb2 section but it doesn’t really help.
