DTS for IMX8MP 2GB/4GB
Hello Toradex Team,
I hope you are all doing great!
We are about to order new SOMs for our next product and we would like to reduce some cost with the SOM. We need less memory than before, so going from 4 → 2 GB. But I just want to be sure that nothing will change for my DTS and I can flash the same OS that I have now.
Can someone confirm that the those 2 SOM can run on the same DTS without any changes:
  • 0058 Verdin iMX8M Plus Quad 4GB WB IT
  • 0064 Verdin iMX8M Plus Quad 2GB WB IT
Thank you for your help!
M
I’d be glad to help clarify the compatibility between these two Verdin iMX8M Plus modules! To provide the most accurate guidance, could you let me know which OS and version you are currently running?
You can get this information by running the tdx-info command on your device. For more details on how to use this command, please see: Getting Device Information with Tdx-Info
This will help me confirm the exact compatibility and any potential considerations for your specific setup.
@ToradexAI here is the tdx-info
Software summary
Kernel version:           5.15.191-6.8.4+git.88e9f1ec02f8 #1-TorizonCore SMP PREEMPT Sun Sep 14 21:18:28 UTC 2025
Kernel command line:      root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/bf4411df75f938287b06cb1f9f94497416082384cb645429cfc2d14157213f25/0
Distro version:           VERSION_ID=6.8.4-build.40
Hostname:                 verdin-imx8mp-XXXXXX
Hardware info
HW model:                 iMX8M Plus on XXXX Board
Toradex version:          0058 V1.1A
Serial number:            XXXXXXX
Based on your tdx-info output showing TorizonCore 6.8.4-build.40 on the 0058 V1.1A module, I can provide clarity on the compatibility between these two modules.
Module Compatibility Analysis
The two modules you’re comparing are:
  • 0058 Verdin iMX8M Plus Quad 4GB WB IT (your current module) (1)
  • 0064 Verdin iMX8M Plus Quad 2GB WB IT (target module) (2)
Hardware Specifications Comparison
Both modules share the same core hardware architecture (1) (3):
CPU & Processing
  • Processor: NXP i.MX 8M Plus Quad with 4 Cortex-A53 cores (3)
  • Cortex-M7: 1 core at 800 MHz (3)
  • GPU: GC7000 UltraLite 3D Graphics Processing Unit (3)
  • NPU: 2.3 TOPS Neural Processing Unit (3)
  • Maximum CPU frequency: 1.6 GHz (A53) for industrial temperature range (3)
Key Differences
The primary difference is the RAM capacity (3):
  • 0058: 4 GB LPDDR4 (3)
  • 0064: 2 GB LPDDR4 (3)
Both use the same LPDDR4 speed (4000 MT/s) and memory width (1x32 bit) (3).
DTS and OS Compatibility
Since both modules use the same SoC (i.MX 8M Plus Quad) and have identical peripheral interfaces (1) (3), your existing device tree configuration should work without modifications. The RAM difference is handled automatically by the bootloader and kernel memory management.
Recommendation
You should be able to use the same TorizonCore 6.8.4 image and device tree configuration on the 0064 module without any changes. The reduced RAM capacity won’t affect peripheral configurations, pin assignments, or interface functionality.
However, ensure your applications can operate within the 2GB memory constraint, especially if you’re running memory-intensive containerized applications.
Hi @unablesalt,
Usually, you don’t need a special device tree for a lower RAM configuration. You can also see from our device tree sources that we do not keep separate device tree files for each RAM configuration. The only thing I can imagine is, if you are using the Cortex M7, maybe you will need to adjust the memory regions in the device tree overlay for HMP. This is hard to confirm without testing.
Another thing that is not device tree related is the RAM requirements for your application (if you have enough RAM for your application). This is also hard to tell without testing. So I would say, give it a try with some testing and let us know if you face any issues.
