I am using the Toradex system-on-module colibri imx6ULL with a custom board.
I am trying to disable the LCD and use it’s GPIOs for my sensors. I have followed the answer in this link. I got stuck with one of the suggestion in the answer.
In addition to assigning these pings to an iomuxc pinctrl group, you’ll also need to assign the pinctrl group to an enabled node for them to get initialized. You can create a new node specifically for this purpose if you’d like.
What does that line mean? Do I need to create a dummy node with
statusproperty set tookay? -
Can I change of the name appearing in /dev/ for uart port?
How can I enable
JTAGin my custom board? -
How can I enable SPI for my board?
My device tree source file is below:
/dts-v1/;
#include "imx6ull-colibri-nonwifi.dtsi"
#include "imx6ull-colibri-eval-v3.dtsi"
model = "Toradex Colibri iMX6ULL 256MB on Colibri Evaluation Board V3";
compatible = "toradex,colibri_imx6ull-eval", "fsl,imx6ull";
&uart1 {
&uart2 {
&uart3 {
&uart4 {
status = "disabled";
&uart5 {
&ecspi1 {
&i2c1 {
/* M41T0M6 real time clock on carrier board */
rtc: m41t0m6@68 {
&pwm1 {
&pwm2 {
&lcdif {
gpio_additional {
pinctrl-name = "default";
pinctrl-0 = <&pinctrl_additionalgpio>;
&ecspi1 {
&iomux {
imx6ull-colibri {
pinctrl_additionalgpio: additionalgpios {
fsl,pins = <
MX6UL_PAD_UART2_RTS_B__GPIO1_IO23 0x14 // Pin 34 => GPS SafeBoot
MX6UL_PAD_CSI_DATA00__GPIO4_IO21 0x14 // Pin 101 => 1V8 Power Supply Enable
MX6UL_PAD_LCD_ENABLE__GPIO3_IO01 0x14 // Pin 44 => GPS EXINT
MX6UL_PAD_LCD_DATA07__GPIO3_IO12 0x14 // Pin 46 => GPS RST
MX6UL_PAD_LCD_DATA09__GPIO3_IO14 0x14 // Pin 48 => UNUSED
MX6UL_PAD_LCD_DATA06__GPIO3_IO11 0x14 // Pin 80 => SX1301 RST
The device tree imx6ull-colibri-nonwifi.dtsi can be found over here.
The device tree imx6ull-colibri-eval-v3.dtsi can be found over here.
