I have hard time configuring DSI to LVDS on a specific board (hugely similar to the verdin development board)
The fact that it’s not the exact same schematic implies that I can’t use prebuilt overlays, and must configure the sn65dsi83 and other devices by myself.
So here is the issues :
I can’t have any display on screen. problem is that I don’t have any signal on clock line out of the Verdin board (so before the sn65dsi83).
pin DSI_1_CLK_N (pin35) and DSI_1_CLK_P (pin31) remain flat on scope at near 0Volt
all others pin seems to send data (DSI_1_Dx_N and DSI_1_Dx_P have all some kind of signal on them)
Also :
I removed the default overlay in /boot/overlays.txt but I can’t manage to remove it from compilation time. on BSP 5.1.0, adding TEZI_EXTERNAL_KERNEL_DEVICETREE_BOOT_remove += “verdin-imx8mm_lt8912_overlay.dtbo” in my image recipe did the trick, but now, I’m unable to remove it by any way (also tried in my layer .conf file, tried with IMAGE_PREPROCESS_COMMAND and IMAGE_POSTPROCESS_COMMAND)
Any help appreciated
Revelant part of the device tree :
/dts-v1/;
#include "imx8mm-verdin.dtsi"
#include "imx8mm-verdin-wifi.dtsi"
//#include "imx8mm-verdin-dev.dtsi"
model = "Toradex Verdin iMX8M Mini WB on Custom Board";
compatible = "toradex,verdin-imx8mm-wifi-dev",
"toradex,verdin-imx8mm-wifi",
"toradex,verdin-imx8mm",
"fsl,imx8mm";
backlight: backlight {
compatible = "pwm-backlight";
brightness-levels = <0 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116>;
default-brightness-level = <80>;
/* Verdin ECSPI1_SS0 (SODIMM 143) enable du backlight*/
enable-gpios = <&gpio5 9 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_backlight_enable>;
power-supply = <®_3p3v>;
/* Verdin PWM_3_DSI/PWM_3_DSI_LVDS (SODIMM 19) */
pwms = <&pwm1 0 6666667 0>; // dernier param : 0 ou PWM_POLARITY_INVERTED
&i2c2 {
clock-frequency = <400000>;
//clock-frequency = <10000>;
pinctrl-0 = <&pinctrl_i2c2>;
bridge@2c {
compatible = "ti,sn65dsi83";
reg = <0x2c>;
ti,dsi-lanes = <4>;
ti,lvds-format = <1>;
ti,lvds-bpp = <24>;
ti,width-mm = <217>;
ti,height-mm = <136>;
/* Verdin MEZ_DSI_1_BKL_EN (SODIMM 21) */
enable-gpios = <&gpio3 3 GPIO_ACTIVE_HIGH>;
/* Verdin MEZ_DSI_1_INT HPD (pulled-down as active-high) (SODIMM 17) */
interrupt-parent = <&gpio3>;
interrupts = <15 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-0 = <&pinctrl_lvds>;
display-timings {
native-mode = <&lvds_timing1>;
lvds_timing1: timing@1 {
clock-frequency = <72400000>;
hactive = <1280>;
hfront-porch = <88>;
hback-porch = <148>;
hsync-len = <44>;
vactive = <800>;
vfront-porch = <4>;
vback-porch = <36>;
vsync-len = <5>;
de-active = <1>;
pixelclk-active = <0>;
port {
dsi85_in: endpoint {
remote-endpoint = <&mipi_dsi_bridge1_out>;
&lcdif {
&mipi_dsi {
port@1 {
reg = <1>;
mipi_dsi_bridge1_out: endpoint {
remote-endpoint = <&dsi85_in>;
attach-bridge;
&gpu {
&iomuxc {
pinctrl_backlight_enable: backlightgrp {
fsl,pins = <
/*enable du backlight*/
MX8MM_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x1c6 /* SODIMM 143 */
pinctrl_pwm_1_custom: backlightpwmgrp {
fsl,pins = <
/*pwm du backlight*/
MX8MM_IOMUXC_GPIO1_IO01_PWM1_OUT 0x6 /* SODIMM 19 */
pinctrl_lvds: lvdsgrp {
fsl,pins = <
/* SN65DSI83 enable */
MX8MM_IOMUXC_NAND_CE2_B_GPIO3_IO3 0x1c4 /* SODIMM 21 */
/* SN65DSI83 interrupt */
MX8MM_IOMUXC_NAND_RE_B_GPIO3_IO15 0x184 /* SODIMM 17 */
/* Verdin PWM_3_DSI (backlight)*/
&pwm1 {
pinctrl-0 = <&pinctrl_pwm_1_custom>;
revelant dmesg output :
[ 2.265887] i2c i2c-0: IMX I2C adapter registered
[ 2.271784] sn65dsi83 1-002c: sn65dsi83_probe
[ 2.276218] sn65dsi83 1-002c: sn65dsi83_brg_power_off
[ 2.298896] sn65dsi83 1-002c: sn65dsi83_brg_power_on
[ 2.314884] sn65dsi83 1-002c: client 0x000000004f8a9e76
[ 2.321648] sn65dsi83 1-002c: sn65dsi83_brg_reset
[ 2.326372] sn65dsi83 1-002c: sn65dsi83_brg_power_off
[ 2.350946] i2c i2c-1: IMX I2C adapter registered
[ 2.357225] i2c i2c-2: IMX I2C adapter registered
[ 2.363644] i2c i2c-3: IMX I2C adapter registered
[ 2.371165] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.377821] [drm] No driver support for vblank timestamp query.
[ 2.383848] imx-drm soc@0:bus@32c00000:display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[ 2.393144] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to get blk_ctl
[ 2.399709] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 2.406722] imx_sec_dsim_drv 32e10000.mipi_dsi: modalias failure on /soc@0/bus@32c00000/mipi_dsi@32e10000/port@1
[ 2.416929] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_bridge_attach
[ 2.424440] sn65dsi83 1-002c: sn65dsi83_attach_dsi
[ 2.429388] imx-drm soc@0:bus@32c00000:display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops)
[ 2.439760] [drm] Initialized imx-drm 1.0.0 20120507 for soc@0:bus@32c00000:display-subsystem on minor 0
[ 2.449278] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_detect
[ 2.457040] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_get_modes
[ 2.465070] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_mode_valid: mode: 1280*800@72400 is valid
[ 2.479754] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_bridge_mode_set: mode: 1280*800@72400
[ 2.483644] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_bridge_enable
[ 2.483650] sn65dsi83 1-002c: sn65dsi83_brg_setup
[ 2.483654] sn65dsi83 1-002c: sn65dsi83_brg_power_on
[ 2.495179] sn65dsi83 1-002c: DSI clock [ 217200000 ] Hz
[ 2.495184] sn65dsi83 1-002c: GeoMetry [ 1280 x 800 ] Hz
[ 2.499915] sn65dsi83 1-002c: client 0x000000004f8a9e76
[ 2.512576] sn65dsi83 1-002c: sn65dsi83_brg_start_stream
[ 2.720065] sn65dsi83 1-002c: client 0x000000004f8a9e76
[ 2.721347] sn65dsi83 1-002c: CHA (0xe5) = 0x01
[ 2.768690] Console: switching to colour frame buffer device 160x50
[ 2.850676] imx-drm soc@0:bus@32c00000:display-subsystem: fb0: imx-drmdrmfb frame buffer device
[ 5.828385] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_detect
[ 5.854580] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_get_modes
[ 5.866576] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_mode_valid: mode: 1280*800@72400 is valid
[ 12.523211] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_detect
[ 12.531003] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_get_modes
[ 12.542558] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_mode_valid: mode: 1280*800@72400 is valid
Thanks!
