Symptoms
● Occasionally see rx packets dropping on ttyLP0
● Bytes in the middle of the packet are dropped
● Communication recovers by itself for the next packet
● No pattern for reproducibility identified
Hardware Setup
● Ixora Carrier board - v1.3A
● Apalis imx8qm
● UART peripherals in use - default device tree config:
○ ttyLP0 - UART 3 (according to datasheet), “No” DMA enabled
○ ttyLP2 - UART 4 (according to datasheet), edma2 enabled
○ No CTS/RTS being used or configured
● Snapshots of dts file obtained from live setup attached
Software Setup
● Baud - 921600
● On ttyLP0, the application process is run that receives a large
chunk of data ~8000 bytes every 2.5s-3s
● SW is configured with a batched size of 100 bytes in a single
UART transfer
RCH/Solutions tried
● Tried running the application code on ttyLP2 and don’t see any
errors indicating DMA may be required
● Tried enabling DMA on ttyLP0 using overlays, but that doesn’t seem to show up in the system
● Below is the overlay that was attempted (used edma 2, ch 12/13 as that’s the default I saw after researching online)
Another observation is I see dma controller err on that channel (among others), not sure what that’s related to
Help Required
● If DMA needs to be enabled to resolve the issue (likely is), it would help to get feedback on the overlay and what am I doing wrong
● Is it advisable to compile the overlay on a system that doesn’t
have access to the full kernel source/without the torizon
builder
● If torizon builder needs to be used
○ Is it advisable to use an overlay?
○ Can the full device tree (with DMA enabled) be built instead of an overlay?
● Is there a specific reason DMA is disabled by default on ttyLP0
and if turning it ON may have any other side effects?
