Driver issue on iMX7
Hi there,
I want to cross compile the driver for SparkLan WUBT-236ACN(BT) WLAN-Stick (GitHub - ulli-kroll/rtl8822bu: rtl8822bu/rtl8812bu driver for linux).
I cloned the Linuxkernel from git://git.toradex.com/linux-toradex.git
Checked out the branch toradex_4.9-2.3.x-imx (toradex_4.9-2.3.x-imx-next doesnt worked too).
I used this description (Quickstart Guide | Toradex Developer Center) for configure my toolchain.
When I start to compile the driver with:
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -i KSRC=~/toradex/linux-toradex/
the compilation works well. But when I try to load the driver with insmod on the Colibri then appears a lot errors like:
Unknown symbol __cfg80211_alloc_event_skb (err 0)
disagrees about version of symbol __netdev_alloc_skb
These errors should give me a clue, that the Kernelversions are not the same. Or is there another reason for these errors ?
My question is, what does do I generally wrong or when not so much, what branch from linux-toradex I should chekout ?
Thanks in advance.
As I unterstand, there
Hi @david_korm
Compiling kernel modules for a running system you need:
  • The exact same kernel-version (in your case 4.9.144 at commit 5758a8e648a3)
  • The exact same defconfig (copy from target /proc/config.gz)
Then you can alter the menuconfig, choose the desired driver and build/deploy it like described here:
Philippe
