Hi there,
from what I gather from the datasheet (http://www.azurewave.com/img/wireless-modules/AW-CM276NF_DS_0B_A_STD.pdf) the WIFI chip on the module does not support WPA3, but I’m not familiar enough with the WPA3 spec to judge whether actual hardware support is required or if a firmware and/or driver update might suffice.
Thanks for any hint in advance
Oliver
