i have attached 2 camera to Apalis T30 with Apalis Eva board, one camera is parallel camera connect to ACM module on carrier board, the orther one is ov5640 based mipi csi-2 camera connected to Apalis T30 mezzanine board. BSP is Linux release V2.5 beta3.
follow instruction of below article, i can capture and display both camera successfully with gstreamer pipelines.
then i want to test capture both camera simultaneously with below pipeline, two display windows are appeared without any error but the image is abnormal, so could you help if Apalis T30 support 2 camera input simultaneously and how?
gst-launch -vvv v4l2src device=/dev/video0 ! ‘video/x-raw-yuv, framerate=30/1’ ! nvvidconv ! nvxvimagesink device=0 &
gst-launch -vvv nv4l2src device=/dev/video1 ! ‘video/x-raw-yuv, width=640, height=480, framerate=30/1’ ! nvvidconv ! nvxvimagesink device=1
thanks a lot!
