Docker.io/library/base:latest: pull access denied
Seemingly out of nothing (meaning that it still worked just today), at one point the build-container-torizon-release-arm64 task stopped building without any significant changes to the build:
Executing task: DOCKER_HOST= docker compose build --pull --build-arg SSHUSERNAME=torizon --build-arg APP_ROOT=/home/torizon/app --build-arg IMAGE_ARCH=arm64 --build-arg GPU=-am62 my-torizon-builder
WARN[0000] The "LOCAL_REGISTRY" variable is not set. Defaulting to a blank string.
Compose can now delegate builds to bake for better performance.
 To do so, set COMPOSE_BAKE=true.
[+] Building 1.2s (5/5) FINISHED                                                           docker:default
 => [my-torizon-builder internal] load build definition from Dockerfile                              0.0s
 => => transferring dockerfile: 4.33kB                                                               0.0s
 => ERROR [my-torizon-builder internal] load metadata for docker.io/library/base:latest              1.0s
 => [my-torizon-builder internal] load metadata for docker.io/torizon/debian:next-rc                 0.8s
 => [my-torizon-builder internal] load metadata for docker.io/torizon/cross-toolchain-arm64:next-rc  0.6s
 => [my-torizon-builder auth] library/base:pull token for registry-1.docker.io                       0.0s
 > [my-torizon-builder internal] load metadata for docker.io/library/base:latest:
failed to solve: base: failed to resolve source metadata for docker.io/library/base:latest: pull access denied, repository does not exist or may require authorization: server message: insufficient_scope: authorization failed
What is that image? Is this some “internal” layer? How could I debug this?
What I tried:
  • created a dockerhub account and ran docker login successfully
  • tried pulling the docker.io/library/base:latest image manually in terminal: same error message
  • added --no-cache to docker build compose
  • ran docker prune --all --force locally to remove all containers
Nothing helped. Any more ideas?
Hello! I see you’re encountering an issue where your Torizon container build is failing due to this error:
This error occurs because docker.io/library/base:latest is not a valid image on Docker Hub and is not intended as a base image for Torizon containers. The Dockerfile is attempting to use a non-existent image, which explains why manual pulls also fail.
What should the base image be?
For Torizon applications, you should use the official Toradex Debian-based images designed for TorizonCore. For ARM64 targets, update your Dockerfile’s base image to:
FROM --platform=linux/arm64 torizon/debian:3-bookworm
Steps to resolve the error:
  1. Edit your Dockerfile:
    Replace any line that starts with FROM base or FROM docker.io/library/base:latest with the recommended Toradex image above.
  2. Check your environment settings:
    The warning:
    suggests your LOCAL_REGISTRY environment variable is not set. While this usually does not stop the build, it’s good practice to set it if you use a local container registry (source).
  3. Clean up build cache and re-run the build:
    After editing the Dockerfile, you can use docker compose build --no-cache again to ensure old cache does not interfere.
  4. Verify your Dockerfile:
    If you’re still experiencing problems, please post the relevant section of your Dockerfile for additional review.
Summary:
This issue likely surfaced now because you previously had the incorrect base image cached locally, and only now did this problem appear due to a cache clear or other change. Using the correct Toradex base image should resolve the error.
For more details, you can refer to the Torizon OS architecture documentation:
As noted by the AI, perhaps the issue surfaced after I added the --no-cache to docker compose build. However, I am able to pull cross-toolchain and debian images just fine…
Greetings @vilchanskyio,
To help investigate the issue could you share the following information:
  • What template is your project based upon?
  • What version of the Torizon IDE extension do you have installed currently?
  • Does this issue happen when you try to execute build-container-torizon-release-arm64 on a fresh project using the same template, or does it only happen when executing this task on your project with your code?
  • Are you on a Windows or Linux PC with VSCode?
Just want to make sure we have all the details before we try to investigate or reproduce this ourselves.
My software stack is:
  • Fedora Linux 41
  • VSCode 1.100.2
  • Torizon IDE Extension 3.1.100 (I am using a pre-release version, because release did not work for me initially a few weeks ago)
  • Docker Engine (docker-ce) 28.2.2
I also installed apt and dpkg-related utilities, which (I assume) are wrappers around dnf on Fedora, just for the xonsh scripts not to hard fail when the command is not found.
When starting afresh (creating a new project from a template), the CMake C/C++ “hello world” template builds and deploys successfully (via build-container-torizon-release-arm64):
Executing task: DOCKER_HOST= docker compose build --pull --build-arg SSHUSERNAME=torizon --build-arg APP_ROOT=/home/torizon/app --build-arg IMAGE_ARCH=arm64 --build-arg GPU=-am62 test-project-container
[+] Building 25.6s (20/20) FINISHED        docker:default
 => [test-project-container internal] load build definition from Dockerfile        0.0s
 => => transferring dockerfile: 2.50kB        0.0s
 => WARN: InvalidDefaultArgInFrom: Default value for ARG torizon/cross-toolchain-${IMAGE_ARCH}:${CROSS_SDK_BASE_TAG} results in empty or invalid base image name (line 15)                                                           0.0s
 => [test-project-container internal] load metadata for docker.io/torizon/debian:4        1.4s
 => [test-project-container internal] load metadata for docker.io/torizon/cross-toolchain-arm64:4        2.3s
 => [test-project-container auth] torizon/debian:pull token for registry-1.docker.io        0.0s
 => [test-project-container auth] torizon/cross-toolchain-arm64:pull token for registry-1.docker.io        0.0s
 => [test-project-container internal] load .dockerignore        0.0s
 => => transferring context: 115B        0.0s
 => [test-project-container build 1/7] FROM docker.io/torizon/cross-toolchain-arm64:4@sha256:75f54951109caff8472c462594d1deae460c183d7aa3b7eab1bf71323b85b1e8        12.6s
 => => resolve docker.io/torizon/cross-toolchain-arm64:4@sha256:75f54951109caff8472c462594d1deae460c183d7aa3b7eab1bf71323b85b1e8        0.1s
 => => sha256:27e2daccb73bc92a1ee43646de13cac88501185d9f358f22eda3f82445694b43 3.51kB / 3.51kB        0.0s
 => => sha256:75f54951109caff8472c462594d1deae460c183d7aa3b7eab1bf71323b85b1e8 1.61kB / 1.61kB        0.0s
 => => sha256:fabae76017d011f088543546c75b1377ab3a2526d075ab00919e1ede0606b83d 9.50kB / 9.50kB        0.0s
 => => sha256:4f4fb700ef54461cfa02571ae0db9a0dc1e0cdb5577484a6d75e68dc38e8acc1 32B / 32B        0.5s
 => => sha256:b1b720b4a1d97ec509012bae116e7894f253cf46af0f1dd890d23e4266382c23 0B / 636B        23.0s
 => => sha256:dad67da3f26bce15939543965e09c4059533b025f707aad72ed3d3f3a09c66f8 28.23MB / 28.23MB        1.9s
 => => sha256:2dec214a3bd3ffb236fa61624711a7168f04d2afd0a861509b332ad57747c13d 6.55MB / 6.55MB        3.9s
 => => extracting sha256:dad67da3f26bce15939543965e09c4059533b025f707aad72ed3d3f3a09c66f8        0.5s
 => => sha256:5697ad4d1033fca9f0148f386f1376ba24d70076ce6576c9448206e1eaeda1e5 268B / 268B        3.2s
 => => sha256:9edb0840aa685b6a1b661d7d0f40cd204cbf1a2fb7391950631fa14c3b822861 256B / 256B        3.2s
 => => sha256:c9a394f5c120cba8bf46bf60e324c0732f1e6c23850b28ed4d46e58ddbf92a5b 3.44kB / 3.44kB        4.1s
 => => sha256:6562e11b49b1e8e4fa75a9ad6057d32c0b6725355954efc97579ba1622220b60 1.97kB / 1.97kB        4.3s
 => => extracting sha256:2dec214a3bd3ffb236fa61624711a7168f04d2afd0a861509b332ad57747c13d        0.1s
 => => sha256:9fc9e985533f598dd13ba759945965df9e4c7de6e80dcfde8e413f417f0445af 406B / 406B        4.9s
 => => extracting sha256:5697ad4d1033fca9f0148f386f1376ba24d70076ce6576c9448206e1eaeda1e5        0.0s
 => => sha256:4679bf9521b81cf0a619a79d104597419835b7b4459e77de679fbe512c00a0f0 15.21MB / 15.21MB        7.0s
 => => extracting sha256:4f4fb700ef54461cfa02571ae0db9a0dc1e0cdb5577484a6d75e68dc38e8acc1        0.0s
 => => extracting sha256:9edb0840aa685b6a1b661d7d0f40cd204cbf1a2fb7391950631fa14c3b822861        0.0s
 => => extracting sha256:b1b720b4a1d97ec509012bae116e7894f253cf46af0f1dd890d23e4266382c23        0.0s
 => => sha256:3bab3bd6f50e3be6e8f6a40f061f7f44f5c8e5e842496a846f4bd94b7d112616 1.18MB / 1.18MB        5.3s
 => => extracting sha256:c9a394f5c120cba8bf46bf60e324c0732f1e6c23850b28ed4d46e58ddbf92a5b        0.0s
 => => extracting sha256:6562e11b49b1e8e4fa75a9ad6057d32c0b6725355954efc97579ba1622220b60        0.0s
 => => extracting sha256:9fc9e985533f598dd13ba759945965df9e4c7de6e80dcfde8e413f417f0445af        0.0s
 => => sha256:85d251d1f4e84bdaa9cf94413034ad29d2c167b2f4400bf7383526e621bbc70c 172B / 172B        5.8s
 => => sha256:99e35793ce659a42171f8faef00dffa62bbb1cde3d4a78d150c03845c679d790 185B / 185B        6.1s
 => => sha256:b4b16cb46c1e2a676ff49d2de6c3001ac24fc8a8d5f4ffd6e3c81cb53e5d9675 135.31MB / 135.31MB        10.3s
 => => extracting sha256:4679bf9521b81cf0a619a79d104597419835b7b4459e77de679fbe512c00a0f0        0.1s
 => => extracting sha256:3bab3bd6f50e3be6e8f6a40f061f7f44f5c8e5e842496a846f4bd94b7d112616        0.0s
 => => extracting sha256:85d251d1f4e84bdaa9cf94413034ad29d2c167b2f4400bf7383526e621bbc70c        0.0s
 => => extracting sha256:99e35793ce659a42171f8faef00dffa62bbb1cde3d4a78d150c03845c679d790        0.0s
 => => extracting sha256:b4b16cb46c1e2a676ff49d2de6c3001ac24fc8a8d5f4ffd6e3c81cb53e5d9675        1.6s
 => [test-project-container internal] load build context        0.1s
 => => transferring context: 196.03kB        0.0s
 => [test-project-container deploy 1/4] FROM docker.io/torizon/debian:4@sha256:89e87a5ad78b8b7741e7209cab96fabdea1893bffe06b036ff3368d2e64063de        2.8s
 => => resolve docker.io/torizon/debian:4@sha256:89e87a5ad78b8b7741e7209cab96fabdea1893bffe06b036ff3368d2e64063de        0.0s
 => => sha256:22f6a2d6b7d90f792f9cea03a005f84908f258bc72f171e1cfdf7c7350da85e8 268B / 268B        0.4s
 => => sha256:6382f28343bdf148663bde65500f9df4d63786602b77aeabfb6380446f468082 6.48kB / 6.48kB        0.0s
 => => sha256:34ef2a75627f6089e01995bfd3b3786509bbdc7cfb4dbc804b642e195340dbc9 28.08MB / 28.08MB        0.5s
 => => sha256:48eaa8f873527b62c792d606ccde1979aeef95165e42a39d96c94e4604433ee8 2.56kB / 2.56kB        0.0s
 => => sha256:e406c0e2542c1395a942d059075c891120a07c3f3c0968b169221804f4fe9df6 6.33MB / 6.33MB        0.6s
 => => sha256:89e87a5ad78b8b7741e7209cab96fabdea1893bffe06b036ff3368d2e64063de 2.38kB / 2.38kB        0.0s
 => => sha256:4f4fb700ef54461cfa02571ae0db9a0dc1e0cdb5577484a6d75e68dc38e8acc1 32B / 32B        0.6s
 => => extracting sha256:34ef2a75627f6089e01995bfd3b3786509bbdc7cfb4dbc804b642e195340dbc9        0.6s
 => => sha256:573ba2e99d63572b20f7d7aa4df3e99df663421fa0e24c64c38b5a6eb8a25433 256B / 256B        1.4s
 => => sha256:d3c29788a7c5235d0790c4d043b015601b7ab14cbc354aa1267e8b146fa34e5d 3.44kB / 3.44kB        0.9s
 => => sha256:b1b720b4a1d97ec509012bae116e7894f253cf46af0f1dd890d23e4266382c23 636B / 636B        0.7s
 => => sha256:9bb49aeb75d7274c4857688795a1596dad13ed31737c829c424ab8e2a9034c9e 1.98kB / 1.98kB        0.9s
 => => sha256:41d0fe4d7bbf44cce23a3c27e525c69240eb49ccb88f14fdd8a6dbfb45386de5 15.05MB / 15.05MB        1.4s
 => => sha256:bf01af6e6be69b69603ebe6ed4f7ce52fce62cb2268adc9459c87af0690172f4 406B / 406B        1.1s
 => => sha256:8effd89b2d8528d1d46fa90637abf7d85bd09213ee383a70e6847f410d0899df 1.21MB / 1.21MB        1.4s
 => => extracting sha256:e406c0e2542c1395a942d059075c891120a07c3f3c0968b169221804f4fe9df6        0.1s
 => => extracting sha256:22f6a2d6b7d90f792f9cea03a005f84908f258bc72f171e1cfdf7c7350da85e8        0.0s
 => => sha256:7b7f3ff35c6306713c9acf0cea647e86fb4b2e27181568cd60c88edc7cb57a57 172B / 172B        2.2s
 => => extracting sha256:573ba2e99d63572b20f7d7aa4df3e99df663421fa0e24c64c38b5a6eb8a25433        0.0s
 => => extracting sha256:d3c29788a7c5235d0790c4d043b015601b7ab14cbc354aa1267e8b146fa34e5d        0.0s
 => => extracting sha256:9bb49aeb75d7274c4857688795a1596dad13ed31737c829c424ab8e2a9034c9e        0.0s
 => => extracting sha256:bf01af6e6be69b69603ebe6ed4f7ce52fce62cb2268adc9459c87af0690172f4        0.0s
 => => extracting sha256:41d0fe4d7bbf44cce23a3c27e525c69240eb49ccb88f14fdd8a6dbfb45386de5        0.1s
 => => extracting sha256:8effd89b2d8528d1d46fa90637abf7d85bd09213ee383a70e6847f410d0899df        0.0s
 => => extracting sha256:7b7f3ff35c6306713c9acf0cea647e86fb4b2e27181568cd60c88edc7cb57a57        0.0s
 => [test-project-container deploy 2/4] RUN apt-get -y update && apt-get install -y --no-install-recommends  && apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*                                                  15.7s
 => [test-project-container build 2/7] RUN apt-get -q -y update &&     apt-get -q -y install     cmake     &&     apt-get clean && apt-get autoremove &&     rm -rf /var/lib/apt/lists/*                                             8.3s
 => [test-project-container build 3/7] COPY . /home/torizon/app        0.1s
 => [test-project-container build 4/7] WORKDIR /home/torizon/app        0.1s
 => [test-project-container build 5/7] RUN rm -rf /home/torizon/app/build-arm64        0.3s
 => [test-project-container build 6/7] RUN if [ "arm64" = "arm64" ] ; then         cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_COMPILER=aarch64-linux-gnu-g++ -DCMAKE_C_COMPILER=aarch64-linux-gnu-gcc -Bbuild-arm64 ;     elif [   0.6s
 => [test-project-container build 7/7] RUN cmake --build build-arm64        0.7s
 => [test-project-container deploy 3/4] COPY --from=build /home/torizon/app/build-arm64/bin /home/torizon/app        0.1s
 => [test-project-container deploy 4/4] WORKDIR /home/torizon/app        0.1s
 => [test-project-container] exporting to image        0.2s
 => => exporting layers        0.1s
 => => writing image sha256:b2a8227d0444266c8dd4eddbf840a0882a30aacde63fa4c724e0a7cd180a58e5        0.0s
 => => naming to localhost:5002/test-project-container:v0.0.0        0.0s
 => [test-project-container] resolving provenance for metadata file        0.0s
[+] Building 1/1
 ✔ test-project-container  Built
I also noticed that the log doesn’t contain any mention of docker.io/library/base:latest. I then also added the --no-cache argument to the task and again, docker compose built just fine. Weird…
I guess the only choice is starting from a fresh template. I will get back to you with an update.
Thank you for your time, it was an error on my side. I accidentally wrote COPY --from=base instead of COPY --from=build, but obviously I had no base layer.
But the Docker error was quite confusing and it could have also pointed me to a particular line…
Ahh I see, you must have modified the Dockerfile then by accident. In any case glad to see your issue was resolved.
