My python application is working fine on my local machine and showing updated GUI and functionality when I am running the application from VS code after choosing “Python local” from drop down. I tried to run the application on the Verdin IMX8MM board choosing “Python ARMv8” from drop down menu from the run option from VS code. Application runs successfully but does not show the updated GUI or functionality, It shows all the old GUI and functionality I had done long back. It seems the device using the old docker image but not the new one. Please suggest
Pramod
It seems like the Verdin iMX8MM board is using an outdated Docker image, which is why you’re seeing the old GUI and functionality. Here are a few steps you can take to resolve this issue:
Ensure the Latest Image is Built: Make sure that you have built the latest version of your Docker image on your local machine. You can do this by running the Docker build command with the appropriate Dockerfile.
Push the Updated Image to a Registry: If you’re using a Docker registry, ensure that the updated image is pushed to the registry. Use the
docker push
command to upload the latest image. -
Pull the Latest Image on the Verdin Board: On the Verdin iMX8MM board, pull the latest image from the registry using the
docker pull
command. This will ensure that the board is using the most recent version of your application. -
Remove Old Containers: Check if there are any old containers running on the Verdin board that might be using the outdated image. Use
docker ps
to list running containers anddocker rm
to remove any that are not needed. -
Run the Updated Container: Start a new container using the updated image. Ensure that you specify the correct image tag when running the container.
Check Docker Compose (if used): If you’re using Docker Compose, make sure the
docker-compose.yml
file is updated with the correct image tag and then rundocker-compose up --force-recreate
to recreate the containers with the latest image.
By following these steps, you should be able to run the updated version of your application on the Verdin iMX8MM board. If the issue persists, double-check the image tags and ensure that the correct image is being used.
Hi @samalpamod ,
Were you able to solve your issue after following suggestions from ToradexAI or still having issues?
