I am unable to open a shell inside my running container with the docker exec option. When I attempt to I receive the following error.
username@colibri-imx6:~$ docker exec -i my_image /bin/bash
http: invalid Host header
It appears I am able to run all other docker commands and it is just exec that is having this issue.
I am using a custom carrier board with the following setup:
- Colibri iMX6DL 512MB IT
- Kernel 5.4.264-5.7.5-devel+git.0dae0c54feaf
I built an image following the Build TorizonCore from Source With Yocto Project/OpenEmbedded process using the containerized TorizonCore Build method and WSL2. The build had the following arguments:
- MANIFEST=dunfell-5.x.y
- MACHINE=colibri-imx6
- DISTRO=torizon-upstream
- IMAGE=torizon-core-docker-colibri-imx6-Tezi_5.4.0+build.10
I have made a few small changes to the final image (username, fstab etc.)
The docker version info is as follows:
username@colibri-imx6:~$ docker version
Client:
Version: 19.03.15-ce
API version: 1.40
Go version: go1.14.15
Git commit: f60dc77833
Built: Tue Feb 13 00:26:38 2024
OS/Arch: linux/arm
Experimental: false
Server:
Engine:
API version: 1.40 (minimum version 1.12)
Git commit: f60dc77833b563cb54a6798e5bf6efd02aba048b
Built: Thu Jan 1 00:00:00 1970
OS/Arch: linux/arm
Experimental: false
containerd:
Version: v1.2.14-3-g3b3e9d5f6.m
GitCommit: 3b3e9d5f62a114153829f9fbe2781d27b0a2ddac.m
runc:
Version: 1.0.0-rc8
GitCommit: 425e105d5a03fabd737a126ad93d62a9eeede87f-dirty
docker-init:
Version: 0.18.0
GitCommit: fec3683-dirty
I have seen this question Docker hello_world not running (and the github discussions on the issue) which appears to be related to my issue but I am having difficulty understanding how to implement the proposed solution.
Let me know if there is any more info required.
Any advice you could offer to overcome this would be very welcome.
Cheers,
Neil
