Dear community,
When applying Torizon OS (6.4.0) lockboxes for combined (docker-compose + OS) offline updates, the docker-compose service is reported as inactive after the reboot from a successful update (aktualizr).
root@colibri-imx8x-00000000:/var/rootdirs/home/torizon# systemctl status docker-compose
* docker-compose.service - Docker Compose service with docker compose
Loaded: loaded (/usr/lib/systemd/system/docker-compose.service; enabled; vendor preset: enabled)
Active: inactive (dead)
Condition: start condition failed at Fri 2023-11-24 07:45:49 UTC; 34min ago
`- ConditionPathExists=!/var/sota/storage/docker-compose/docker-compose.yml.tmp was not met
Nov 24 07:45:45 colibri-imx8x-00000000 systemd[1]: Docker Compose service with docker compose was skipped because of a failed condition check (ConditionPathExists=!/var/sota/storage/do>
Nov 24 07:45:49 colibri-imx8x-00000000 systemd[1]: Docker Compose service with docker compose was skipped because of a failed condition check (ConditionPathExists=!/var/sota/storage/do
It seems like it expects to have no tmp file from the update (/var/sota/storage/docker-compose/docker-compose.yml.tmp). But at the time when checking the docker-compose status, this file doesn’t exist (anymore).
When rebooting the system again (manually), everything seems ok and the docker-compose service comes up fine and is active.
Is this behavior something to worry about (e.g. because of a misconfiguration on our side) or can it be ignored (I don’t know the side effect of the docker-service in an inactive state)?
Thanks for your help.
Lukas
