Running Colibir iMX6ULL WB with Linux Console image 2.8b3.111 and trying to setup an Access Point on internal Wifi. Stated with a fresh image and changed the following:
# opkg update
# opkg install dnsmasq
Only changes made to:
/etc/hostapd.conf
interface=uap0
ssid=watereye
hw_mode=g // default
channel=1 // default
own_ip_addr=192.168.8.1
#wpa=1 // no wpa
/etc/dnsmasq.conf
interface=uap0
dhcp-range=192.168.8.50,192.168.8.150,2h
no-hosts
To stop clash on Port 53 between connman and dnsmasq. add --nodnsporxy to connman ExecStart:
/lib/systemd/system/connman.service,
ExecStart=/usr/sbin/connmand -n --nodnsproxy
To provide the uap0 with an address and use dns, create the following file:
/etc/systemd/network/hostapd.network
[Match]
Name=uap0
[Network]
Address=192.168.8.1/24
DHCPServer=yes
Enable the required serivices
# connmanctl enable wifi
# systemctl enable hostapd
# systemctl enable dnsmasq
# reboot
- no errors in system load
- ssid on wifi can be seen but no connection
Run # ifconfig
eth0 Link encap:Ethernet HWaddr 00:14:2D:2E:E4:79
inet addr:192.168.1.60 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::214:2dff:fe2e:e479%lo/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
uap0 Link encap:Ethernet HWaddr 00:19:88:5E:11:4E
inet6 addr: fe80::219:88ff:fe5e:114e%lo/64 Scope:Link
No IP address appearing on uap0
Run # lsof -i -P -n
dnsmasq 300 nobody 4u IPv4 6054 0t0 UDP *:67
dnsmasq 300 nobody 6u IPv4 6057 0t0 UDP *:53
dnsmasq 300 nobody 7u IPv4 6058 0t0 TCP *:53 (LISTEN)
dnsmasq 300 nobody 8u IPv6 6059 0t0 UDP *:53
dnsmasq 300 nobody 9u IPv6 6060 0t0 TCP *:53 (LISTEN)
Run # systemctl status hostapd
hostapd.service - Hostapd IEEE 802.11 AP, IEEE 802.1X/WPA/WPA2/EAP/RADIUS Authenticator
Loaded: loaded (/lib/systemd/system/hostapd.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2018-08-07 18:32:54 UTC; 1min 51s ago
Process: 291 ExecStart=/usr/sbin/hostapd /etc/hostapd.conf -P /run/hostapd.pid -B (code=exited, status=0/SUCCESS)
Main PID: 301 (hostapd)
CGroup: /system.slice/hostapd.service
+-301 /usr/sbin/hostapd /etc/hostapd.conf -P /run/hostapd.pid -B
Aug 07 18:32:54 colibri-imx6ull hostapd[291]: uap0: interface state UNINITIALIZED->ENABLED
Aug 07 18:32:54 colibri-imx6ull hostapd[291]: uap0: AP-ENABLED
Aug 07 18:32:54 colibri-imx6ull systemd[1]: hostapd.service: PID file /run/hostapd.pid not readable (yet?) after start: No such file or directo
Aug 07 18:32:54 colibri-imx6ull systemd[1]: Started Hostapd IEEE 802.11 AP, IEEE 802.1X/WPA/WPA2/EAP/RADIUS Authenticator.
Aug 07 18:33:24 colibri-imx6ull hostapd[301]: uap0: STA fc:42:03:ea:1c:3f IEEE 802.11: associated
Aug 07 18:33:24 colibri-imx6ull hostapd[301]: uap0: STA fc:42:03:ea:1c:3f RADIUS: starting accounting session 62BFCC3A963EAE7A
Aug 07 18:33:56 colibri-imx6ull hostapd[301]: uap0: STA fc:42:03:ea:1c:3f IEEE 802.11: disassociated
Aug 07 18:33:58 colibri-imx6ull hostapd[301]: uap0: STA fc:42:03:ea:1c:3f IEEE 802.11: associated
Aug 07 18:33:58 colibri-imx6ull hostapd[301]: uap0: STA fc:42:03:ea:1c:3f RADIUS: starting accounting session 4152A684EA598958
Aug 07 18:34:31 colibri-imx6ull hostapd[301]: uap0: STA fc:42:03:ea:1c:3f IEEE 802.11: disassociated
Run # systemctl status dnsmasq
dnsmasq.service - DNS forwarder and DHCP server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2018-08-07 18:32:54 UTC; 2min 18s ago
Process: 297 ExecStart=/usr/bin/dnsmasq -x /run/dnsmasq.pid -7 /etc/dnsmasq.d --local-service (code=exited, status=0/SUCCESS)
Process: 292 ExecStartPre=/usr/bin/dnsmasq --test (code=exited, status=0/SUCCESS)
Main PID: 300 (dnsmasq)
CGroup: /system.slice/dnsmasq.service
+-300 /usr/bin/dnsmasq -x /run/dnsmasq.pid -7 /etc/dnsmasq.d --local-service
Aug 07 18:32:55 colibri-imx6ull dnsmasq[300]: reading /etc/resolv.conf
Aug 07 18:32:55 colibri-imx6ull dnsmasq[300]: using nameserver 192.168.1.1#53
Aug 07 18:33:25 colibri-imx6ull dnsmasq-dhcp[300]: DHCP packet received on uap0 which has no address
Aug 07 18:33:29 colibri-imx6ull dnsmasq-dhcp[300]: DHCP packet received on uap0 which has no address
Aug 07 18:33:37 colibri-imx6ull dnsmasq-dhcp[300]: DHCP packet received on uap0 which has no address
Aug 07 18:33:53 colibri-imx6ull dnsmasq-dhcp[300]: DHCP packet received on uap0 which has no address
Aug 07 18:33:59 colibri-imx6ull dnsmasq-dhcp[300]: DHCP packet received on uap0 which has no address
Aug 07 18:34:02 colibri-imx6ull dnsmasq-dhcp[300]: DHCP packet received on uap0 which has no address
Aug 07 18:34:10 colibri-imx6ull dnsmasq-dhcp[300]: DHCP packet received on uap0 which has no address
Aug 07 18:34:27 colibri-imx6ull dnsmasq-dhcp[300]: DHCP packet received on uap0 which has no address
If i now stop dnsmasq and restart it mannul with logging, I get the following:
Run # dnsmasq --no-daemon --log-queries
dnsmasq: started, version 2.78 cachesize 150
dnsmasq: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth no-DNSSEC loop-detect inotify
dnsmasq-dhcp: DHCP, IP range 192.168.8.50 -- 192.168.8.150, lease time 2h
dnsmasq: reading /etc/resolv.conf
dnsmasq: using nameserver 192.168.1.1#53
dnsmasq: cleared cache
// when a client tries to connect, get following
dnsmasq-dhcp: DHCP packet received on uap0 which has no address
Now if i disable dsnmasq then reboot, the uap0 IP address appears:
Loaded: loaded (/lib/systemd/system/dnsmasq.service; disabled; vendor preset: enabled)
Active: inactive (dead)
Run #ifconfig
inet addr:192.168.8.1 Bcast:192.168.8.255 Mask:255.255.255.0
When DNSMASQ is running, i am not getting an IP address for the wifi AP (uap0) and the AP is not allowing connection.
Any advise on where the problem may be or what to try would be greatly appreciated.
