Display Tweak tool for Apalis T30?
I’m trying to adjust display settings on my Apalis T30 module (running WEC2013). If I launch ‘ColibriTweak’ I get an error message that says ‘ColibriTweak’ is not a valid Windows Embedded Compact application.
Is there a version of ColibriTweak that works on my setup?
The problem here is not the Apalis but Windows Embedded Compact 2013. WEC2013 is not binary compatible to CE 6 and WEC 7, currently Colibri Tweak is not available for WEC 2013.
In case you plan to use Colibri Tweak to config the display settings, just use it under WEC 7 and export the registry settings to import them under CE 8.
