We want to display the HDMI and LCD output simultaneously with different monitors. we have done with the following commands at runtime in U Boot console and Bootloader Env variables in uEnv.txt
setenv vidargs video=mxcfb1:video=dev=hdmi,800x480M@60,if=RGB24 video=mxcfb0:dev=lcd,800x480@60,if=RGB666 fbmem=32M
vidargs'mxc_hdmi.only_cea=1 video=mxcfb1:dev=hdmi,800x480M@60,if=RGB24 video=mxcfb0:dev=lcd,800x480@60,if=RGB666 fbmem=32M'
After Executing the above commands we are able to get only one display at a time for another one only signal.
Note:only mxcfb0(framebuffer) output will display either HDMI or LCD
We also tried updating kernel using overlay modules “colibri-imx6_lcd-lt161010_overlay.dtbo” and "colibri-imx6_hdmi_overlay.dtbo " in /boot but here also we can select one at a time.
Kindly correct me if i have misconfigured above data.
Is there a way to display HDMI and LCD outputs simultaneously ?
Image : Colibri-iMX6_Reference-Minimal-Image-Tezi_5.4.0
Linux Kernel : 5.4.91-5.2.0-devel+git.c59b3c2da1e9
SOM :IMX6QDL
Hi @Gowthami ,
Can you please share your overlay.txt content and output of ls /sys/class/drm command.
Also please use Reference multimedia image for testing. You may need to modify weston to enable second display as per resolution and type of display.
Ritesh Kumar
Hello @ritesh.tx ,
1.We can use Reference multimedia image but the image is too heavy and it has lot of QT stuffs which we are not using.
2.Output of ls /sys/class/drm card0 renderD128 version
3.Yes we have modified the /etc/xdg/weston /vi weston.ini to enable the second display as mentioned below.
[output]
name=DPI-1
mode=640x480@60
[output]
name=HDMI-A-1
clone-from=DPI-1
- Overlays.txt content fdt_overlays=colibri-imx6_lcd-vga_overlay.dtbo colibri-imx6_hdmi_overlay.dtbo
overlays.txt (78 Bytes)
Note:We’re moving on to the carrier board development phase and a quick support will be highly appreciated.
Hi @Gowthami,
Quickly checking, I can see multiple framebuffer
root@colibri-imx6:~# cat /etc/issue
TDX Wayland with XWayland 5.3.0+build.10 (dunfell) \n \l
Colibri-iMX6_Reference-Multimedia-Image
root@colibri-imx6:~# fw_printenv vidargs
vidargs=video=mxcfb1:video=dev=hdmi,1024x600@60,if=RGB24 video=mxcfb0:dev=lcd,800x480@60,if=RGB666 fbmem=32M
root@colibri-imx6:~# ls /dev/fb*
/dev/fb /dev/fb0 /dev/fb1 /dev/fb2
iMX6 do not support such configuration. Perhaps you can try from application itself, don’t know what performance to expect. One way is to use gstreamer pipeline e.g
gst-launch-1.0 -v multifilesrc location=/dev/fb0 ! videoparse format=29 width=800 height=480 framerate=30/1 ! decodebin ! videoscale ! video/x-raw,width=1024,height=600 ! videoconvert ! fbdevsink device=/dev/fb2 sync=false
Another method would be to start two application using individual framebuffer.
Ritesh Kumar
Hello @ritesh.tx
Requirement is to enable the different peripherals (LCD and HDMI) simultaneously through SOM itself.
Enabling from Application is not recommended.
Thank you for concluding the issue quickly.
