Display issues such as the one you’re describing, where the title bar is not rendered correctly, can indeed stem from various sources, including hardware-related problems like insufficient voltage supply. For the Colibri iMX6 module, ensuring that the device is supplied with the correct voltage is crucial for stable operation, including the proper rendering of graphical user interfaces (GUIs).
Low voltage can lead to unpredictable behavior due to the inability of the system to properly power all components. This can affect the GPU or display interfaces, leading to rendering issues or instability in the display output. It’s important to verify that your power supply meets the requirements specified for the Colibri iMX6 module, which typically includes stable voltage within the recommended range.
If the issue coincides with logs indicating low voltage, it’s highly likely that the display errors are a consequence of this. Addressing the power supply issue should be the first step in troubleshooting this problem. Ensure that the power supply is capable of delivering consistent voltage within the specified range for the Colibri iMX6, even under load.
After resolving any power supply issues, if the problem persists, it may be worth investigating other potential causes, such as software configuration, display interface settings, or even the display panel itself. However, based on the information provided, starting with the power supply is the most direct approach.
Toradex AI Assistant
Device Tree Overlays on Toradex System on Modules | Toradex Developer Center.
