Hi Jaski,
Thanks for your reply.
Our module: Apalis iMX6 Quad 2GB IT V1.1C, Qt5-X11-Image 2.8b2 20180713
We are working on a Qt/Qml graphical application with CAN-Bus input. It will be the only application on the board and should start up in 10 sec. The current start-up time of the application alone is 6 sec so we are trying to reduce the boot-up time as far as possible. Here are the serial boot logs obtained with (grabserial -t -d /dev/USB0):
Default:
[0.000001 0.000001]
[0.000829 0.000828]
[0.000892 0.000063] U-Boot 2016.11-2.8.2+g087e95a (Jun 10 2018 - 03:37:16 -0400)
[0.005834 0.004942]
[0.005881 0.000047] CPU: Freescale i.MX6Q rev1.5 at 792 MHz
[0.007490 0.001609] Reset cause: POR
[0.007973 0.000483] I2C: ready
[0.008866 0.000893] DRAM: 2 GiB
[0.061343 0.052477] PMIC: device id: 0x10, revision id: 0x21, programmed
[0.063263 0.001920] MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
[0.189116 0.125853] auto-detected panel HDMI
[0.204852 0.015736] Display: HDMI (1024x768)
[0.236789 0.031937] In: serial
[0.237491 0.000702] Out: serial
[0.238069 0.000578] Err: serial
[0.261184 0.023115] Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 05184618
[0.263287 0.002103] Net: using PHY at 7
[0.277760 0.014473] FEC [PRIME]
[0.278458 0.000698] Hit any key to stop autoboot: 0
[0.303137 0.024679] Booting from internal eMMC chip...
[0.304195 0.001058] reading imx6q-apalis-eval.dtb
[0.318654 0.014459] 54314 bytes read in 18 ms (2.9 MiB/s)
[0.320001 0.001347] reading zImage
[0.453696 0.133695] 3451704 bytes read in 110 ms (29.9 MiB/s)
[0.455076 0.001380] ## Flattened Device Tree blob at 12000000
[0.456430 0.001354] Booting using the fdt blob at 0x12000000
[0.457662 0.001232] Using Device Tree in place at 12000000, end 12010429
[0.459163 0.001501]
[0.459197 0.000034] Starting kernel ...
[0.459798 0.000601]
[4.788131 4.328333] [ 3.969750] vgaarb: this pci device is not a vga device
[4.964148 0.176017] [ 4.137690] vgaarb: this pci device is not a vga device
[5.475909 0.511761]
[5.536335 0.060426] .---O---.
[5.540433 0.004098] | | .-. o o
[5.547116 0.006683] | | |-----.-----.-----.| | .----..-----.-----.
[5.548550 0.001434] | | | __ | ---'| '--.| .-'| | |
[5.550371 0.001821] | | | | | |--- || --'| | | ' | | | |
[5.552954 0.002583] '---'---'--'--'--. |-----''----''--' '-----'-'-'-'
[5.554760 0.001806] -' |
[5.555376 0.000616] '---'
[5.556062 0.000686]
[5.556097 0.000035] The Angstrom Distribution apalis-imx6 ttymxc0
[5.557353 0.001256]
[5.557388 0.000035] Angstrom v2017.12 - Kernel
[5.558208 0.000820]
[5.558242 0.000034] Apalis-iMX6_Qt5-X11-Image 2.8b2 20180713
[5.559540 0.001298]
[5.567321 0.007781] apalis-imx6 login:
Masked journald services:
[0.000001 0.000001]
[0.000772 0.000771]
[0.000974 0.000202] U-Boot 2016.11-2.8.2+g087e95a (Jun 10 2018 - 03:37:16 -0400)
[0.002914 0.001940]
[0.002954 0.000040] CPU: Freescale i.MX6Q rev1.5 at 792 MHz
[0.009207 0.006253] Reset cause: POR
[0.009814 0.000607] I2C: ready
[0.010181 0.000367] DRAM: 2 GiB
[0.046116 0.035935] PMIC: device id: 0x10, revision id: 0x21, programmed
[0.048219 0.002103] MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
[0.190361 0.142142] auto-detected panel HDMI
[0.205844 0.015483] Display: HDMI (1024x768)
[0.238219 0.032375] In: serial
[0.238934 0.000715] Out: serial
[0.239501 0.000567] Err: serial
[0.260833 0.021332] Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 05184618
[0.262846 0.002013] Net: using PHY at 7
[0.277687 0.014841] FEC [PRIME]
[0.278048 0.000361] Hit any key to stop autoboot: 0
[0.303731 0.025683] Booting from internal eMMC chip...
[0.304883 0.001152] reading imx6q-apalis-eval.dtb
[0.319223 0.014340] 54314 bytes read in 18 ms (2.9 MiB/s)
[0.320606 0.001383] reading zImage
[0.512215 0.191609] 3451704 bytes read in 110 ms (29.9 MiB/s)
[0.513993 0.001778] ## Flattened Device Tree blob at 12000000
[0.516130 0.002137] Booting using the fdt blob at 0x12000000
[0.518096 0.001966] Using Device Tree in place at 12000000, end 12010429
[0.519612 0.001516]
[0.519646 0.000034] Starting kernel ...
[0.520134 0.000488]
[2.716498 2.196364] [ 1.866251] systemd[1]: systemd-journald-dev-log.socket: Socket service systemd-journald.service not loaded, refusing.
[2.721161 0.004663] [ 1.877210] systemd[1]: Failed to listen on Journal Socket (/dev/log).
[2.723352 0.002191] [e[0;1;31mFAILEDe[0m] Failed to listen on Journal Socket (/dev/log).
[2.745248 0.021896] See 'systemctl status systemd-journald-dev-log.socket' for details.
[2.746487 0.001239] [e[0;32m OK e[0m] Listening on udev Kernel Socket.
[2.761256 0.014769] [e[0;32m OK e[0m] Created slice User and Session Slice.
[2.809444 0.048188] [e[0;32m OK e[0m] Reached target Remote File Systems.
[2.825445 0.016001] [e[0;32m OK e[0m] Started Dispatch Password Requests to Console Directory Watch.
[2.875402 0.049957] [e[0;32m OK e[0m] Reached target Host and Network Name Lookups.
[2.891410 0.016008] [e[0;32m OK e[0m] Created slice System Slice.
[2.937452 0.046042] Mounting Kernel Debug File System...
[3.031559 0.094107] [e[0;32m OK e[0m] Reached target Slices.
[3.085797 0.054238] [e[0;32m OK e[0m] Created slice system-serial\x2dgetty.slice.
[3.088115 0.002318] [e[0;32m OK e[0m] Created slice system-getty.slice.
[3.092479 0.004364] [e[0;32m OK e[0m] Listening on udev Control Socket.
[3.093908 0.001429] [e[0;32m OK e[0m] Reached target Paths.
[3.099121 0.005213] [e[0;1;31mFAILEDe[0m] Failed to listen on Journal Socket.
[3.131797 0.032676] See 'systemctl status systemd-journald.socket' for details.
[3.163525 0.031728] Starting File System Check on Root Device...
[3.195200 0.031675] Starting Load Kernel Modules...
[3.244341 0.049141] Starting Export GPIOs to user space...
[3.245986 0.001645] [e[0;32m OK e[0m] Listening on /dev/initctl Compatibility Named Pipe.
[3.252286 0.006300] [e[0;32m OK e[0m] Listening on Network Service Netlink Socket.
[3.255184 0.002898] [e[0;32m OK e[0m] Reached target Swap.
[3.259782 0.004598] Mounting Temporary Directory (/tmp)...
[3.261168 0.001386] [e[0;32m OK e[0m] Mounted Kernel Debug File System.
[3.262661 0.001493] [e[0;32m OK e[0m] Mounted Temporary Directory (/tmp).
[3.302045 0.039384] [e[0;32m OK e[0m] Started Load Kernel Modules.
[3.303774 0.001729] Starting Apply Kernel Variables...
[3.309179 0.005405] Mounting Kernel Configuration File System...
[3.310873 0.001694] [e[0;32m OK e[0m] Mounted Kernel Configuration File System.
[3.314568 0.003695] [e[0;32m OK e[0m] Started Export GPIOs to user space.
[3.316091 0.001523] [e[0;32m OK e[0m] Started Apply Kernel Variables.
[3.318814 0.002723] [e[0;32m OK e[0m] Started File System Check on Root Device.
[3.350130 0.031316] Starting Remount Root and Kernel File Systems...
[3.403187 0.053057] [e[0;32m OK e[0m] Started Remount Root and Kernel File Systems.
[3.435514 0.032327] Starting udev Coldplug all Devices...
[3.451484 0.015970] Starting Create Static Device Nodes in /dev...
[3.497441 0.045957] [e[0;32m OK e[0m] Started Create Static Device Nodes in /dev.
[3.513368 0.015927] [e[0;32m OK e[0m] Reached target Local File Systems (Pre).
[3.561261 0.047893] Mounting /var/volatile...
[3.593036 0.031775] Starting udev Kernel Device Manager...
[3.684722 0.091686] [e[0;32m OK e[0m] Mounted /var/volatile.
[3.687037 0.002315] [ 2.813749] systemd-udevd[129]: Invalid rule /lib/udev/rules.d/73-seat-late.rules:15: RUN{builtin}: 'uaccess' unknown
[3.695817 0.008780] [e[0;32m OK e[0m] Started udev Kernel Device Manager.
[3.722184 0.026367] Starting Load/Save Random Seed...
[3.724568 0.002384] [e[0;32m OK e[0m] Reached target Local File Systems.
[3.743609 0.019041] Starting Create Volatile Files and Directories...
[3.770316 0.026707] [e[0;32m OK e[0m] Started Load/Save Random Seed.
[3.786298 0.015982] [e[0;32m OK e[0m] Started Create Volatile Files and Directories.
[3.839287 0.052989] Starting Update UTMP about System Boot/Shutdown...
[3.887034 0.047747] [e[0;32m OK e[0m] Started udev Coldplug all Devices.
[3.967290 0.080256] [e[0;32m OK e[0m] Found device /dev/ttymxc0.
[4.014316 0.047026] [e[0;32m OK e[0m] Started Update UTMP about System Boot/Shutdown.
[4.030370 0.016054] [e[0;32m OK e[0m] Reached target System Initialization.
[4.077427 0.047057] [e[0;32m OK e[0m] Listening on D-Bus System Message Bus Socket.
[4.106277 0.028850] [e[0;32m OK e[0m] Started Daily Cleanup of Temporary Directories.
[4.122460 0.016183] [e[0;32m OK e[0m] Reached target Timers.
[4.166240 0.043780] [e[0;32m OK e[0m] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[4.195964 0.029724] [e[0;32m OK e[0m] Listening on RPCbind Server Activation Socket.
[4.212303 0.016339] Starting Console System Startup Logging...
[4.244138 0.031835] Starting sshd.socket.
[4.292015 0.047877] [e[0;32m OK e[0m] Started Console System Startup Logging.
[4.388102 0.096087] [e[0;32m OK e[0m] Listening on sshd.socket.
[4.740051 0.351949] [e[0;32m OK e[0m] Reached target Sound Card.
[4.798453 0.058402] [e[0;32m OK e[0m] Reached target Sockets.
[4.803967 0.005514] [e[0;32m OK e[0m] Reached target Basic System.
[4.836078 0.032111] [e[0;32m OK e[0m] Reached target Containers.
[4.868000 0.031922] Starting start X and a qt application...
[4.899853 0.031853] [e[0;32m OK e[0m] Started D-Bus System Message Bus.
[5.027757 0.127904] Starting Connection service...
[5.097579 0.069822] Starting Load default USB gadget schema g1.schema...
[5.113768 0.016189] Starting Login Service...
[5.145751 0.031983] Starting Avahi mDNS/DNS-SD Stack...
[5.177587 0.031836] Starting Save/Restore Sound Card State...
[5.209689 0.032102] [e[0;32m OK e[0m] Started Timestamping service.
[5.233840 0.024151] [e[0;32m OK e[0m] Started start X and a qt application.
[5.234933 0.001093] [e[0;32m OK e[0m] Started Save/Restore Sound Card State.
[5.265841 0.030908] [e[0;32m OK e[0m] Started Login Service.
[5.329935 0.064094] [e[0;32m OK e[0m] Started Connection service.
[5.361608 0.031673] [e[0;32m OK e[0m] Started Avahi mDNS/DNS-SD Stack.
[5.505907 0.144299] [e[0;32m OK e[0m] Started Load default USB gadget schema g1.schema.
[5.553533 0.047626] Starting Network Service...
[5.725751 0.172218] [e[0;32m OK e[0m] Started Network Service.
[5.726315 0.000564] [ 4.896047] vgaarb: this pci device is not a vga device
[5.821699 0.095384] [e[0;32m OK e[0m] Reached target Network.
[5.941194 0.119495] [ 5.067790] vgaarb: this pci device is not a vga device
[5.941815 0.000621] Starting Permit User Sessions...
[5.963164 0.021349] [e[0;32m OK e[0m] Started Permit User Sessions.
[6.027222 0.064058] [e[0;32m OK e[0m] Started Getty on tty1.
[6.059241 0.032019] [e[0;32m OK e[0m] Started Serial Getty on ttymxc0.
[6.075178 0.015937] [e[0;32m OK e[0m] Reached target Login Prompts.
[6.123129 0.047951] [e[0;32m OK e[0m] Reached target Multi-User System.
[6.155268 0.032139] [e[0;32m OK e[0m] Reached target Graphical Interface.
[6.199203 0.043935] Starting Update UTMP about System Runlevel Changes...
[6.258139 0.058936] [e[0;32m OK e[0m] Started Update UTMP about System Runlevel Changes.
[7.283927 1.025788]
[7.347089 0.063162] .---O---.
[7.347964 0.000875] | | .-. o o
[7.348725 0.000761] | | |-----.-----.-----.| | .----..-----.-----.
[7.349159 0.000434] | | | __ | ---'| '--.| .-'| | |
[7.349672 0.000513] | | | | | |--- || --'| | | ' | | | |
[7.350221 0.000549] '---'---'--'--'--. |-----''----''--' '-----'-'-'-'
[7.350724 0.000503] -' |
[7.350860 0.000136] '---'
[7.350997 0.000137]
[7.351004 0.000007] The Angstrom Distribution apalis-imx6 ttymxc0
[7.351377 0.000373]
[7.351392 0.000015] Angstrom v2017.12 - Kernel
[7.351996 0.000604]
[7.352016 0.000020] Apalis-iMX6_Qt5-X11-Image 2.8b2 20180713
[7.362116 0.010100]
[7.378022 0.015906] apalis-imx6 login:
Journald.conf → Storage=None:
[0.000001 0.000001]
[0.000698 0.000697]
[0.000784 0.000086] U-Boot 2016.11-2.8.2+g087e95a (Jun 10 2018 - 03:37:16 -0400)
[0.027693 0.026909]
[0.027742 0.000049] CPU: Freescale i.MX6Q rev1.5 at 792 MHz
[0.029080 0.001338] Reset cause: POR
[0.029671 0.000591] I2C: ready
[0.030083 0.000412] DRAM: 2 GiB
[0.070579 0.040496] PMIC: device id: 0x10, revision id: 0x21, programmed
[0.070921 0.000342] MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
[0.215100 0.144179] auto-detected panel HDMI
[0.230871 0.015771] Display: HDMI (1024x768)
[0.263051 0.032180] In: serial
[0.263631 0.000580] Out: serial
[0.263994 0.000363] Err: serial
[0.286063 0.022069] Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 05184618
[0.288167 0.002104] Net: using PHY at 7
[0.302367 0.014200] FEC [PRIME]
[0.302844 0.000477] Hit any key to stop autoboot: 0
[0.328662 0.025818] Booting from internal eMMC chip...
[0.329782 0.001120] reading imx6q-apalis-eval.dtb
[0.343995 0.014213] 54314 bytes read in 18 ms (2.9 MiB/s)
[0.345194 0.001199] reading zImage
[0.479014 0.133820] 3451704 bytes read in 110 ms (29.9 MiB/s)
[0.480348 0.001334] ## Flattened Device Tree blob at 12000000
[0.481473 0.001125] Booting using the fdt blob at 0x12000000
[0.482721 0.001248] Using Device Tree in place at 12000000, end 12010429
[0.484361 0.001640]
[0.484399 0.000038] Starting kernel ...
[0.485042 0.000643]
[4.814057 4.329015] [ 3.971333] vgaarb: this pci device is not a vga device
[5.038007 0.223950] [ 4.188399] vgaarb: this pci device is not a vga device
[5.981857 0.943850]
[6.042817 0.060960] .---O---.
[6.044982 0.002165] | | .-. o o
[6.046936 0.001954] | | |-----.-----.-----.| | .----..-----.-----.
[6.048892 0.001956] | | | __ | ---'| '--.| .-'| | |
[6.050646 0.001754] | | | | | |--- || --'| | | ' | | | |
[6.052233 0.001587] '---'---'--'--'--. |-----''----''--' '-----'-'-'-'
[6.057992 0.005759] -' |
[6.062790 0.004798] '---'
[6.063433 0.000643]
[6.063479 0.000046] The Angstrom Distribution apalis-imx6 ttymxc0
[6.064698 0.001219]
[6.064732 0.000034] Angstrom v2017.12 - Kernel
[6.065549 0.000817]
[6.065582 0.000033] Apalis-iMX6_Qt5-X11-Image 2.8b2 20180713
[6.067630 0.002048]
[6.073659 0.006029] apalis-imx6 login:
Journald.conf → Storage=None & reduced log levels:
[0.000001 0.000001]
[0.000477 0.000476]
[0.000528 0.000051] U-Boot 2016.11-2.8.2+g087e95a (Jun 10 2018 - 03:37:16 -0400)
[0.003417 0.002889]
[0.003463 0.000046] CPU: Freescale i.MX6Q rev1.5 at 792 MHz
[0.006149 0.002686] Reset cause: POR
[0.006678 0.000529] I2C: ready
[0.007305 0.000627] DRAM: 2 GiB
[0.045795 0.038490] PMIC: device id: 0x10, revision id: 0x21, programmed
[0.049443 0.003648] MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
[0.189804 0.140361] auto-detected panel HDMI
[0.205724 0.015920] Display: HDMI (1024x768)
[0.237895 0.032171] In: serial
[0.238957 0.001062] Out: serial
[0.240028 0.001071] Err: serial
[0.260762 0.020734] Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 05184618
[0.263173 0.002411] Net: using PHY at 7
[0.277478 0.014305] FEC [PRIME]
[0.278029 0.000551] Hit any key to stop autoboot: 0
[0.303262 0.025233] Booting from internal eMMC chip...
[0.304365 0.001103] reading imx6q-apalis-eval.dtb
[0.318789 0.014424] 54314 bytes read in 18 ms (2.9 MiB/s)
[0.320112 0.001323] reading zImage
[0.453642 0.133530] 3451704 bytes read in 110 ms (29.9 MiB/s)
[0.455641 0.001999] ## Flattened Device Tree blob at 12000000
[0.457509 0.001868] Booting using the fdt blob at 0x12000000
[0.459462 0.001953] Using Device Tree in place at 12000000, end 12010429
[0.461247 0.001785]
[0.461269 0.000022] Starting kernel ...
[0.461563 0.000294]
[4.788327 4.326764] [ 3.973181] vgaarb: this pci device is not a vga device
[4.979925 0.191598] [ 4.167618] vgaarb: this pci device is not a vga device
[5.412030 0.432105]
[5.476991 0.064961] .---O---.
[5.479816 0.002825] | | .-. o o
[5.481590 0.001774] | | |-----.-----.-----.| | .----..-----.-----.
[5.483450 0.001860] | | | __ | ---'| '--.| .-'| | |
[5.485201 0.001751] | | | | | |--- || --'| | | ' | | | |
[5.486930 0.001729] '---'---'--'--'--. |-----''----''--' '-----'-'-'-'
[5.489166 0.002236] -' |
[5.489725 0.000559] '---'
[5.490701 0.000976]
[5.490739 0.000038] The Angstrom Distribution apalis-imx6 ttymxc0
[5.492730 0.001991]
[5.492785 0.000055] Angstrom v2017.12 - Kernel
[5.493983 0.001198]
[5.494048 0.000065] Apalis-iMX6_Qt5-X11-Image 2.8b2 20180713
[5.495499 0.001451]
[5.507576 0.012077] apalis-imx6 login:
Best regards
