During our testing, we discovered that DHCP client is always active, independent on systemd-networkd settings. Even with networkd disabled (systemctl disable systemd-networkd), the board still acquires IP address when connected to a network.
Configuring with static IP address:
$ cat /etc/systemd/netword/wired-network
[Match]
Name=eth0
[Network]
Address=192.168.111.177/24
Gateway=192.168.111.1
DNS=192.168.111.1
gets two addresses: one from DHCP, one static.
So, the simple question is: How is the DHCP client started? How to enable / disable it when needed?
Configuration: Based on Toradex’ reference image
Colibri-6: $ su -c tdx-info.sh
Password:
Software summary
Bootloader: U-Boot
Kernel version: 5.4.193-rt74-5.7.3-devel+git.49e4130e2197 #1 SMP PREEMPT_RT Tue Apr 11 21:14:29 UTC 2023
Kernel command line: user_debug=30 ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0
Distro name: NAME="TDX Wayland with XWayland RT"
Distro version: VERSION_ID=5.7.3-devel-20230823013514-build.0
Hostname: colibri-07131122
Hardware info
HW model: Toradex Colibri iMX6ULL 256MB on Colibri Evaluation Board V3
Toradex version: 0036 V1.1A
Serial number: 07131122
Processor arch: armv7l
