Hello, We are using our application on WinCE7 in IMX6.
we tried to apply black image mentioned in this link. But it gives error “Error opening image file. The file must be in the root folder of the active partition of the SD card”. But same SD card works on VF61. Also I seen same issue mentioned here. Is there any different setting for IMX6?.
I’m confused. Initially you said “we tried to apply black image mentioned in this link.” But that page has only image for VFxx modules. So could you please provide more details:
How do you get mentioned Blackimage.tss ?
Can you share it if you created it by yourself?
How did you “tried to apply black image”?
Why just disabling splash screen as described here doesn’t work for you?
@alex.tx Here I attached Black image which is provided by Toradex. Initially we will use black image and later we will be using our company logo hence we just disabling splash screen
