I’m currenty using UART2, which is configured using a custom dts file.
This looks like this (a snippet from the dts file):
#include "imx6dl.dtsi"
#include "imx6qdl-colibri.dtsi"
&iomuxc {
pinctrl-names = "default";
pinctrl-0 = <
&pinctrl_gpio
gpio {
pinctrl_gpio: gpio-custom {
fsl,pins = <
MX6QDL_PAD_SD4_DAT5__GPIO2_IO13 PAD_CTRL_HYS_PU /* SODIMM 34 */
&uart2 {
/* Delete the uart-has-rtscts property so these pins can be used as IO */
/delete-property/fsl,uart-has-rtscts;
With the configuration above I’m trying to disable the RTS and CTS pins of UART2 so these pins can be used as regular IO.
Unfortunately when I try this using the dts file above, the UART2 device driver handler (/dev/ttymxc1) disappears from the user-space after flashing the new image.
Does anyone know what I’m missing?
Thanks in advance!
