We would like to use jumbo frames to send UDP video stream pacakges at Colibri. Destination is a fixed device and no other switch/router exist.
After some research, found this question, and it directs to NXP forums page. But to patch does not exist.
When checked the NPX forum page, a comment denotes disabling the store-and-forward mode allows bigger frames. After some search at the kernel source, I found this line denotes enables store and forward mode:
Also, I have checked eth KSZ8041NL
chip driver, which is located at drivers/net/phy/micrel.c
at kernel source, but couldn’t figure out is capable of disabling that mode.
Also, we do not have throuhgput more than 400Mbps limit that noted at ERR004512:
Is it the right way to comment out this line to disable store-and-forward mode ?
How can I disable store-and-forward mode ?
Thanks,
