I am trying to compile a C++ application using a Dockerfile for TorizonCore. Using the template C++ project as a basis and changing it for my app (which uses vcpkg and cmake) I arrived there:
ARG CROSS_SDK_BASE_TAG=3-bookworm
ARG BASE_VERSION=3-bookworm
ARG IMAGE_ARCH=arm64
ARG APP_EXECUTABLE=my_application
# BUILD ------------------------------------------------------------------------
FROM torizon/debian-cross-toolchain-${IMAGE_ARCH}:${CROSS_SDK_BASE_TAG} As Build
ARG IMAGE_ARCH
ARG COMPILER_ARCH
ENV IMAGE_ARCH ${IMAGE_ARCH}
# __deps__
RUN apt-get -q -y update && \
apt-get -q -y install \
clang-tidy \
cmake \
cppcheck \
curl \
iwyu \
mono-complete \
ninja-build \
pkg-config \
python3 \
unzip \
uuid-dev uuid-runtime \
zip \
# DOES NOT REMOVE THIS LABEL: this is used for VS Code automation
# __torizon_packages_dev_start__
# __torizon_packages_dev_end__
apt-get clean && apt-get autoremove && \
rm -rf /var/lib/apt/lists/*
# __deps__
# Download vcpkg
RUN git clone --branch 2023.01.09 https://github.com/microsoft/vcpkg
# Setup vcpkg
RUN cd vcpkg && \
./bootstrap-vcpkg.sh && \
cd / && \
chmod -R 777 vcpkg
# Set environment variables
ENV VCPKG_ROOT="/vcpkg"
COPY . /app
WORKDIR /app
RUN if [ "$IMAGE_ARCH" = "arm64" ] ; then \
cmake --preset ci-aarch64 . && \
cmake --build build/ --target my_application_exe ; \
mkdir -p aarch64/bin aarch64/debug aarch64/obj ; \
cp build/my_application aarch64/bin ; \
fi
# DEPLOY ------------------------------------------------------------------------
FROM --platform=linux/${IMAGE_ARCH} torizon/debian:${BASE_VERSION} AS Deploy
ARG IMAGE_ARCH
ARG APP_EXECUTABLE
ENV APP_EXECUTABLE ${APP_EXECUTABLE}
RUN apt-get -y update && apt-get install -y --no-install-recommends \
# __torizon_packages_prod_start__
# __torizon_packages_prod_end__
&& apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
# copy the build
COPY --from=Build /app/aarch64/bin /app
# ADD YOUR ARGUMENTS HERE
#CMD [ "./app/my_application" ]
But, there is a difference in glibc version between the debian-cross-toolchain and the debian images.
For the debian-cross-toolchain image:
root@ec84cfa702a5:/# ./usr/aarch64-linux-gnu/lib/libc.so.6
GNU C Library (Debian GLIBC 2.36-3) stable release version 2.36.
For the debian image:
root@6c0c42755a7b:/# /lib/aarch64-linux-gnu/libc.so.6
GNU C Library (Debian GLIBC 2.34-3) stable release version 2.34.
Thus, launching my application, I get /lib/aarch64-linux-gnu/libc.so.6: version 'GLIBC_2.36' not found (required by ./my_application)
