Apalis iMX8 Max
Torizon 6.6
Custom carrier board
We built the 6.6.0 torizon-core-docker image with Yocto and tested it in our custom carrier board. USB works, wifi works.
After this we apply our custom device tree and the usb’s do not work anymore.
lsusb output is
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
We tested this with ixora and eval board DT. same problem
dmesg reports continuous
[ 1911.942209] usb usb1-port1: attempt power cycle
[ 1912.412149] usb 1-1: new high-speed USB device number 124 using ci_hdrc
[ 1912.852153] usb 1-1: device not accepting address 124, error -71
[ 1913.002154] usb 1-1: new high-speed USB device number 125 using ci_hdrc
[ 1913.442183] usb 1-1: device not accepting address 125, error -71
[ 1913.448291] usb usb1-port1: unable to enumerate USB device
With the 5.7.1 build we had no issues and everything worked. Are there any changes in the devicetree?
We also get PCIe PLL lock timeout as an error. Devicetree did not change from 5.7.1 to 6.6.0
