I’m trying to compile my first custom build of device tree for iMX6DL and I ran into a problem.
I’ve been using the instructions from the following pages, but now I’m stuck.
http://developer.toradex.com/device-tree-customization
http://developer.toradex.com/knowledge-base/build-u-boot-and-linux-kernel-from-source-code
I tried running the command make dtbs from /u-boot-toradex$ but I get the following error.
LD u-boot
DTC
arch/arm/dts/imx6ull-14x14-evk.dtbDTC
arch/arm/dts/imx6dl-icore.dtbDTC arch/arm/dts/imx6q-icore.dtb
Device Tree Source is not correctly
specified.Please define
‘CONFIG_DEFAULT_DEVICE_TREE’or build with
‘DEVICE_TREE=’ argumentmake1: *** [arch/arm/dts/unset.dtb]
Error 1
Can you give me an idea of what I might be doing wrong? I have no problem using U-boot to create an SD Card and flash Linux to my module using the correct configuration.
Thanks.
Scott
