We designed a carrier board with a Colibri Module, and we are currently doing the new device tree of the board.
We are new in this, and I have a small question.
We used the SODIMM Pin n°86, EIM_ADDR25 of SoC as a GPIO. So i configure it as a GPIO in the file imx6dl.dtsi:
MX6QDL_PAD_EIM_A25__GPIO5_IO02 PAD_CTRL_HYS_PU
But in another section, this pin is already declared:
/* pins used on module */
imx6dl-colibri {
pinctrl_spi_cs1: spi_cs1 {
fsl,pins = <
MX6QDL_PAD_EIM_A25__GPIO5_IO02 PAD_CTRL_NO /* SPI cs */
Do I need to comment these lines?
Pierre-Olivier
Rather than comment it out, I’d recommend disabling the node which uses the pin (ecspi4). This can be done in the dts file (imx6dl-colibri-eval-v3.dts):
&ecspi4 {
/* status = "okay"; */
status = "disabled";
Alternatively, if you must use the SPI interface, leave it enabled, and configure a different pin for the chip select (in the code below, pinctrl_spi_cs_alt must be another pinctrl binding which you define with an alternate chip select pin for the interface).
&ecspi4 {
/* Override: pinctrl-0 = <&pinctrl_ecspi4 &pinctrl_spi_cs1>; */
pinctrl-0 = <&pinctrl_ecspi4 &pinctrl_spi_cs_alt>;
Thanks for your help, I already defined a new CS pin, so it’s fine.
