Hi @jaski.tx,
Thanks for the response. Alright, now I could pass through some obstacles but there are some left.
Here are my modified files in branch 4.9-2.3.
Now I have the leds subsystem OK
Q1: I have no longer VGA video out -after the disablings I had to perform to get the GPIOs pins-. Is there sth I can do here to keep both things?
Q2: rled2 is always on and rled5 is always off and I can’t understand why.
Q3: Is there a way to flash just the dtb file? I am using recovery mode + Toradex Easy Installer with image.json for the uploading and that also uploads the rootfs.
Q4: btn0 doesn’t appear in the gpio-keys subsytem.
My dmesg:
root@colibri-imx6ull:~# dmesg
[ 0.000000] Linux version 4.14.126-00877-gbaa7eae49e3f (gaston@ssd-gbassi) (gcc version 8.2.0 (GCC)) #2 SMP Mon Dec 9 13:55:44 -03 2019
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Toradex Colibri iMX6ULL 256MB on Colibri Aster
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x98000000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat 80d7de80, node_mem_map 97bb8000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 16 pages/cpu s34892 r8192 d22452 u65536
[ 0.000000] pcpu-alloc: s34892 r8192 d22452 u65536 alloc=16*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: user_debug=30 ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0 video=mxsfb:640x480M-16@60
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 375028K/524288K available (8192K kernel code, 506K rwdata, 2268K rodata, 1024K init, 384K bss, 18188K reserved, 131072K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xa0800000 - 0xff800000 (1520 MB)
[ 0.000000] lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80900000 (9184 kB)
[ 0.000000] .init : 0x80c00000 - 0x80d00000 (1024 kB)
[ 0.000000] .data : 0x80d00000 - 0x80d7eaa0 ( 507 kB)
[ 0.000000] .bss : 0x80d80000 - 0x80de0148 ( 385 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] Switching to timer-based delay loop, resolution 333ns
[ 0.000016] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[ 0.000060] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.003800] Console: colour dummy device 80x30
[ 0.004758] console [tty1] enabled
[ 0.004814] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.004888] pid_max: default: 32768 minimum: 301
[ 0.005182] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.005247] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.006610] CPU: Testing write buffer coherency: ok
[ 0.008083] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.008470] Hierarchical SRCU implementation.
[ 0.009786] smp: Bringing up secondary CPUs ...
[ 0.009846] smp: Brought up 1 node, 1 CPU
[ 0.009889] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[ 0.009926] CPU: All CPU(s) started in SVC mode.
[ 0.011605] devtmpfs: initialized
[ 0.029493] random: get_random_u32 called from bucket_table_alloc+0x108/0x238 with crng_init=0
[ 0.030615] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.031232] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.031329] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.042210] pinctrl core: initialized pinctrl subsystem
[ 0.044164] NET: Registered protocol family 16
[ 0.057704] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.059660] cpuidle: using governor menu
[ 0.072384] vdd3p0: supplied by regulator-dummy
[ 0.073574] cpu: supplied by regulator-dummy
[ 0.074729] vddsoc: supplied by regulator-dummy
[ 0.095360] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.095438] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.097118] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.099087] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[ 0.143026] soc_in: supplied by +V3.3
[ 0.143814] eth_phy: supplied by +V3.3
[ 0.145888] VCC_USB[1-4]: supplied by 5V
[ 0.148408] SCSI subsystem initialized
[ 0.148967] usbcore: registered new interface driver usbfs
[ 0.149126] usbcore: registered new interface driver hub
[ 0.149393] usbcore: registered new device driver usb
[ 0.151840] i2c i2c-0: IMX I2C adapter registered
[ 0.151921] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.153327] i2c i2c-1: IMX I2C adapter registered
[ 0.153404] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.153932] Linux video capture interface: v2.00
[ 0.154111] pps_core: LinuxPPS API ver. 1 registered
[ 0.154154] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.154260] PTP clock support registered
[ 0.154903] Advanced Linux Sound Architecture Driver Initialized.
[ 0.157266] clocksource: Switched to clocksource mxc_timer1
[ 0.157568] VFS: Disk quotas dquot_6.6.0
[ 0.157766] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.178543] NET: Registered protocol family 2
[ 0.179930] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.180084] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.180268] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.180490] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.180581] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.180949] NET: Registered protocol family 1
[ 0.181881] RPC: Registered named UNIX socket transport module.
[ 0.181947] RPC: Registered udp transport module.
[ 0.181983] RPC: Registered tcp transport module.
[ 0.182018] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.186914] Bus freq driver module loaded
[ 0.189724] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.201568] NFS: Registering the id_resolver key type
[ 0.201684] Key type id_resolver registered
[ 0.201725] Key type id_legacy registered
[ 0.201784] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.203067] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.203758] fuse init (API version 7.26)
[ 0.222634] io scheduler noop registered
[ 0.222700] io scheduler deadline registered
[ 0.223068] io scheduler cfq registered (default)
[ 0.223123] io scheduler mq-deadline registered
[ 0.223163] io scheduler kyber registered
[ 0.226180] mxsfb 21c8000.lcdif: 21c8000.lcdif supply lcd not found, using dummy regulator
[ 0.226729] fbcvt: 640x480@60: CVT Name - .307M3
[ 0.226793] mxsfb 21c8000.lcdif: Using timings from kernel parameters
[ 0.338843] Console: switching to colour frame buffer device 80x30
[ 0.358445] mxsfb 21c8000.lcdif: initialized
[ 0.365735] mxs-dma 1804000.dma-apbh: initialized
[ 0.373196] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 19, base_baud = 5000000) is a IMX
[ 1.056489] console [ttymxc0] enabled
[ 1.065718] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 57, base_baud = 5000000) is a IMX
[ 1.083143] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 58, base_baud = 5000000) is a IMX
[ 1.118787] loop: module loaded
[ 1.133940] random: fast init done
[ 1.144361] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
[ 1.154600] nand: Macronix MX30LF4G28AC
[ 1.162190] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 112
[ 1.178130] gpmi-nand 1806000.gpmi-nand: mode:5 ,failed in set feature.
[ 1.189501] Bad block table found at page 262080, version 0x01
[ 1.200196] Bad block table found at page 262016, version 0x01
[ 1.211310] 5 ofpart partitions found on MTD device gpmi-nand
[ 1.221344] Creating 5 MTD partitions on "gpmi-nand":
[ 1.230586] 0x000000000000-0x000000080000 : "mx6ull-bcb"
[ 1.240906] 0x000000080000-0x000000200000 : "u-boot1"
[ 1.250897] 0x000000200000-0x000000380000 : "u-boot2"
[ 1.260762] 0x000000380000-0x000000400000 : "u-boot-env"
[ 1.270825] 0x000000400000-0x000020000000 : "ubi"
[ 1.292026] gpmi-nand 1806000.gpmi-nand: driver registered.
[ 1.304759] libphy: Fixed MDIO Bus: probed
[ 1.316101] pps pps0: new PPS source ptp0
[ 1.326348] libphy: fec_enet_mii_bus: probed
[ 1.337002] fec 20b4000.ethernet eth0: registered PHC device 0
[ 1.348846] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.359108] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.368328] usbcore: registered new interface driver usb-storage
[ 1.378172] usbcore: registered new interface driver usbserial
[ 1.387635] usbcore: registered new interface driver usbserial_generic
[ 1.397753] usbserial: USB Serial support registered for generic
[ 1.407142] usbcore: registered new interface driver ftdi_sio
[ 1.416320] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.430143] usbcore: registered new interface driver pl2303
[ 1.439094] usbserial: USB Serial support registered for pl2303
[ 1.450624] usbmisc_imx 2184800.usbmisc: 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.473898] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.482520] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.517350] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.528193] hub 1-0:1.0: USB hub found
[ 1.535668] hub 1-0:1.0: 1 port detected
[ 1.553174] input: AD7879 Touchscreen as /devices/soc0/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-002c/input/input0
[ 1.574739] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-rtc-lp as rtc0
[ 1.592311] i2c /dev entries driver
[ 1.600857] IR NEC protocol handler initialized
[ 1.609647] IR RC5(x/sz) protocol handler initialized
[ 1.618666] IR RC6 protocol handler initialized
[ 1.627008] IR JVC protocol handler initialized
[ 1.635264] IR Sony protocol handler initialized
[ 1.643678] IR SANYO protocol handler initialized
[ 1.652466] IR Sharp protocol handler initialized
[ 1.660948] IR MCE Keyboard/mouse protocol handler initialized
[ 1.670551] IR XMP protocol handler initialized
[ 1.682478] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.693368] sdhci: Secure Digital Host Controller Interface driver
[ 1.703349] sdhci: Copyright(c) Pierre Ossman
[ 1.711354] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.722679] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 1.797922] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 1.824892] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.834625] usbcore: registered new interface driver usbhid
[ 1.844014] usbhid: USB HID core driver
[ 1.857182] Netfilter messages via NETLINK v0.30.
[ 1.865906] nfnl_acct: registering with nfnetlink.
[ 1.874891] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[ 1.885122] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[ 1.896087] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.905931] NET: Registered protocol family 10
[ 1.916373] Segment Routing with IPv6
[ 1.923728] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 1.934082] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.943443] NET: Registered protocol family 17
[ 1.952038] Bridge firewalling registered
[ 1.959969] 8021q: 802.1Q VLAN Support v1.8
[ 1.968038] Key type dns_resolver registered
[ 2.007505] Registering SWP/SWPB emulation handler
[ 2.015102] registered taskstats version 1
[ 2.052110] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 2.068675] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:105C passive:95C
[ 2.084325] ubi0: default fastmap pool size: 200
[ 2.091054] ubi0: default fastmap WL pool size: 100
[ 2.097869] ubi0: attaching mtd4
[ 2.151451] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 2.161413] scsi host0: usb-storage 1-1:1.0
[ 2.999883] random: crng init done
[ 3.220013] scsi 0:0:0:0: Direct-Access USB Flash Memory 1.00 PQ: 0 ANSI: 4
[ 3.243391] sd 0:0:0:0: [sda] 30310400 512-byte logical blocks: (15.5 GB/14.5 GiB)
[ 3.260098] sd 0:0:0:0: [sda] Write Protect is off
[ 3.266966] sd 0:0:0:0: [sda] Mode Sense: 45 00 00 00
[ 3.267925] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 3.286931] sda: sda1
[ 3.296082] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 4.482900] ubi0: scanning is finished
[ 4.520672] ubi0: attached mtd4 (name "ubi", size 508 MiB)
[ 4.530278] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 4.541308] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 4.552258] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 4.563432] ubi0: good PEBs: 4060, bad PEBs: 4, corrupted PEBs: 0
[ 4.573646] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
[ 4.588775] ubi0: max/mean erase counter: 165/64, WL threshold: 4096, image sequence number: 187033344
[ 4.606075] ubi0: available PEBs: 0, total reserved PEBs: 4060, PEBs reserved for bad PEB handling: 76
[ 4.624335] ubi0: background thread "ubi_bgt0d" started, PID 99
[ 4.632931] snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 2019-12-10 18:27:25 UTC (1576002445)
[ 4.647866] soc_in: disabling
[ 4.653064] ALSA device list:
[ 4.658224] No soundcards found.
[ 4.666095] UBIFS (ubi0:3): background thread "ubifs_bgt0_3" started, PID 100
[ 4.816256] UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "rootfs"
[ 4.832080] UBIFS (ubi0:3): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 4.850581] UBIFS (ubi0:3): FS size: 493936640 bytes (471 MiB, 3890 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 4.870291] UBIFS (ubi0:3): reserved for root: 0 bytes (0 KiB)
[ 4.880767] UBIFS (ubi0:3): media format: w4/r0 (latest is w5/r0), UUID E44A9EED-072E-42D9-8AA6-3E409632F4B8, small LPT model
[ 4.904996] VFS: Mounted root (ubifs filesystem) on device 0:12.
[ 4.915991] devtmpfs: mounted
[ 4.922746] Freeing unused kernel memory: 1024K
[ 6.256873] udevd[122]: starting version 3.2.7
[ 6.371619] udevd[122]: specified group 'kvm' unknown
[ 6.437195] udevd[123]: starting eudev-3.2.7
[ 6.601708] udevd[123]: specified group 'kvm' unknown
[ 9.337635] Micrel KSZ8041 20b4000.ethernet-1:02: attached PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=20b4000.ethernet-1:02, irq=POLL)
[ 9.366855] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.488418] fec 20b4000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 12.513113] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
