I’m trying to determine why overwriting a node according to the: Device Tree Customization document does not seem to work.
I am following the suggestion in the document to create a carrier board specific file where changes to nodes can be made to add or modify properties that are specific to our carrier board. The node that I’m attempting to overwrite is first defined in the imx7s.dtsi file:
lcdif: lcdif@30730000 {
compatible = "fsl,imx7d-lcdif", "fsl,imx28-lcdif";
reg = <0x30730000 0x10000>;
interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX7D_LCDIF_PIXEL_ROOT_CLK>,
<&clks IMX7D_CLK_DUMMY>,
<&clks IMX7D_CLK_DUMMY>;
clock-names = "pix", "axi", "disp_axi";
status = "disabled";
It is then overwritten in the imx7-colibri-eval-v3.dtsi file:
&lcdif {
display = <&display0>;
display0: lcd-display {
bits-per-pixel = <16>;
bus-width = <18>;
display-timings {
native-mode = <&timing_wvga>;
/* Standard VGA timing */
timing_vga: 640x480 {
clock-frequency = <25175000>;
hactive = <640>;
vactive = <480>;
hback-porch = <40>;
hfront-porch = <24>;
vback-porch = <32>;
vfront-porch = <11>;
hsync-len = <96>;
vsync-len = <2>;
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
pixelclk-active = <0>;
/* WVGA Timing, e.g. EDT ET070080DH6 */
timing_wvga: 800x480 {
clock-frequency = <33260000>;
hactive = <800>;
vactive = <480>;
hback-porch = <216>;
hfront-porch = <40>;
vback-porch = <35>;
vfront-porch = <10>;
hsync-len = <128>;
vsync-len = <2>;
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
/* WVGA Timing, TouchRevolution Fusion 7" */
timing_wvga2: 800x480pixclkact {
hactive = <800>;
vactive = <480>;
vback-porch = <35>;
hsync-len = <128>;
vsync-len = <2>;
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
pixelclk-active = <1>;
/* Standard SVGA timing */
timing_svga: 800x600 {
clock-frequency = <40000000>;
hactive = <800>;
vactive = <600>;
hback-porch = <88>;
vback-porch = <23>;
vfront-porch = <1>;
hsync-len = <128>;
vsync-len = <4>;
de-active = <1>;
hsync-active = <1>;
vsync-active = <1>;
/* TouchRevolution Fusion 10"/CLAA101NC05 10.1 inch */
timing_wsvga: 1024x600 {
clock-frequency = <48000000>;
hactive = <1024>;
vactive = <600>;
hback-porch = <104>;
hfront-porch = <43>;
vback-porch = <24>;\
vfront-porch = <20>;
hsync-len = <5>;
vsync-len = <5>;
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
/* Standard XGA timing */
timing_xga: 1024x768 {
clock-frequency = <65000000>;
hactive = <1024>;
vactive = <768>;
hback-porch = <160>;
vback-porch = <29>;
vfront-porch = <3>;
hsync-len = <136>;
vsync-len = <6>;
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
I am overwritting this in our carrier board specific file imx7d-colibri-p1100.dts:
&lcdif {
bus-width = <18>;
display-timings {
native-mode = <&my_wvga>;
my_wvga: 800x480Tesco {
hactive = <800>;
vactive = <480>;
hback-porch = <40>;
vback-porch = <34>;
vfront-porch = <13>;
hsync-len = <45>;
vsync-len = <3>; // 0x3E
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
When I build the file imx7d-colibri-p1100.dtb it will build successfully, but when I update the imx7d with the new dtb file I build it is using the definition of lcdif in the imx7-colibri-eval-v3.dtsi file, not the overwritten lcdif in the imx7d-colibri-p1100.dts file.
My understanding, based on the information in the Device Tree Customization document linked above, is that overwritting nodes in later dtsi files overwrites nodes from earlier dtsi files.
I don’t understand why my overwrite did not work? Can nodes only be overwritten one time?
The only way that I’ve been able to get this to work is to completely comment out the overwrite of the lcdif node in the imx7-colibri-eval-v3.dtsi file. Then the overwrite in the imx7d-colibri-p1100.dts file will work.
Thank You
