Device Tree Configuration GPIO LED
I want to export GPIO leds (52,55) to the user space where it can be controlled from an userspace program.
When I try to see the exported GPIO’s from the terminal I get the following output.
sh-4.3# cat /sys/kernel/debug/gpio
GPIOs 0-31, platform/209c000.gpio, 209c000.gpio:
GPIOs 32-63, platform/20a0000.gpio, 20a0000.gpio:
 gpio-37  (cd                  ) in  hi
 gpio-52  (?                   ) out lo
 gpio-54  (Wake-Up             ) in  lo
 gpio-55  (?                   ) out lo
GPIOs 64-95, platform/20a4000.gpio, 20a4000.gpio:
 gpio-84  (spi_imx             ) out lo
 gpio-88  (spi_imx             ) out lo
 gpio-89  (spi_imx             ) out lo
 gpio-95  (usb_host_vbus       ) out lo
GPIOs 96-127, platform/20a8000.gpio, 20a8000.gpio:
 gpio-108 (scl                 ) in  hi
 gpio-109 (sda                 ) in  hi
GPIOs 128-159, platform/20ac000.gpio, 20ac000.gpio:
 gpio-130 (spi_imx             ) out lo
 gpio-145 (spi_imx             ) out lo
GPIOs 160-191, platform/20b0000.gpio, 20b0000.gpio:
GPIOs 192-223, platform/20b4000.gpio, 20b4000.gpio:
 gpio-204 (id                  ) in  lo
I can control the LEDs from the GPIO-Tool which shows that we have the lines correct.
Here is my device tree (copied from Apalis IMX6): imx6dl-colibri-eval-v3.dts
 &iomuxc {
      * Mux all pins which are unused to be GPIOs
      * so they are ready for export to user space
     pinctrl-names = "default";
     pinctrl-0 = <&pinctrl_weim_gpio_1 &pinctrl_weim_gpio_2
                  &pinctrl_weim_gpio_3 &pinctrl_weim_gpio_4
                  &pinctrl_weim_gpio_5 &pinctrl_weim_gpio_6
                  &pinctrl_csi_gpio_1
                  &pinctrl_gpio_1
                  &pinctrl_gpio_2
                  &pinctrl_usbh_oc_1 &pinctrl_usbc_id_1>;
     gpio {
         pinctrl_pcap_1: pcap-1 {
             fsl,pins = <
                 MX6QDL_PAD_GPIO_9__GPIO1_IO09    PAD_CTRL_HYS_PD /* SODIMM 28 */
                 MX6QDL_PAD_SD4_DAT2__GPIO2_IO10    PAD_CTRL_HYS_PD /* SODIMM 30 */
     leds_colibri {
         pinctrl_leds_colibri: leds-colibri {
             fsl,pins = <
                 MX6QDL_PAD_EIM_CS0__GPIO2_IO23 PAD_CTRL_HYS_PU
                 MX6QDL_PAD_EIM_A18__GPIO2_IO20 PAD_CTRL_HYS_PU
leds { compatible = "gpio-leds";
         pinctrl-0 = <&pinctrl_leds_colibri>;
         led1-red {
             label = "LED_1_RED";
             gpios = <&gpio2 23 GPIO_ACTIVE_HIGH>;
         led2-green {
             label = "LED_2_GREEN";
             gpios = <&gpio2 20 GPIO_ACTIVE_HIGH>;
Can someone let me know what am I doing wrong here?
If I have a export extra GPIOs, Do i just include them in this node ?
Also, would it be possible to work up a little code snippet that shows me what I need to include to actually read the state of the input pins and control the state of the output pins?
IOs configured with gpio-leds driver will appear in /sys/class/leds . LED class allows control of LEDs from userspace. Have a look at the leds-class documentation for more information.
This is a good resource to start with for anyone who comes across this post
