Deploying device-tree overlay using torizoncore-builder
Hi Team,
I’m currently working on the integration of MSP3520 TFT Display on Verdin development board (via SPI), which has verdin am62 SoM integrated.
We tried with SPI1, which is readily enabled in the verdin dev board. We could see our display is working fine. But we need to connect the display via SPI2. The pins we had selected were -
SPI2:
SODIMM_131 → CLK
SODIMM_133 → D1 (MISO)
SODIMM_135 → D0 (MOSI)
SODIMM_129 → CS0 (Display)
SODIMM_30 → CS1 (Touch Controller)
For GPIO, we are using dedicated GPIO pins:-
GPIO:
SODIMM_206 → DC/RS
SODIMM_208 → Reset
SODIMM_210 → Backlight
I created an overlay file for this:-
:penguin: root @GalaxyBook/home/Meenakshy/Projects/SPI_TFT_Display/tcbdir: cat device-trees/overlays/verdin-am62_msp3520_tft_display_spi2_overlay.dts
/dts-v1/;
/plugin/;
#include “k3-pinctrl.h”
compatible = “toradex,verdin-am62”;
/\* Verdin SPI_2 pins */*
*&main_pmx0 {*
*main_spi2_pins_default: main-spi2-pins-default {*
*pinctrl-single,pins = <*
*AM62X_IOPAD(0x01b0, PIN_OUTPUT, 1) /* SPI2_CLK - SODIMM_131 */*
*AM62X_IOPAD(0x0198, PIN_INPUT, 1) /* SPI2_D1 - SODIMM_133 - MISO */*
*AM62X_IOPAD(0x0194, PIN_OUTPUT, 1) /* SPI2_D0 - SODIMM_135 - MOSI */*
*AM62X_IOPAD(0x01ac, PIN_OUTPUT, 1) /* SPI2_CS0 - SODIMM_129 */*
*AM62X_IOPAD(0x01a4, PIN_OUTPUT, 1) /* SPI2_CS1 - SODIMM_30 \*/
/\* Disable UART4 to free up pins for SPI2. SODIMM_131 is used by UART4 \*/
&main_uart4 {
status = “disabled”;
/\* Verdin SPI_2 - Enable for LCD \*/
&main_spi2 {
pinctrl-names = “default”;
pinctrl-0 = <&main_spi2_pins_default>;
status = “okay”;
    #address-cells = <1>;
    #size-cells = <0>;
msp3520_display@0 {
            compatible = "spidev";
            reg = <0>;
            spi-max-frequency = <10000000>;
msp3520_touch@1 {
            reg = <1>;
@GalaxyBoo@GalaxyBoo@GalaxyBook root @GalaxyBook/home/Meenakshy/Projects/SPI_TFT_Display/tcbdir:
The steps for deployment that I followed are -
mkdir tcbdir
cd tcbdir
wget https://raw.githubusercontent.com/toradex/tcb-env-setup/master/tcb-env-setup.sh
source tcb-env-setup.sh
torizoncore-builder --help //Test whether the torizoncore-builder command is available
Downloaded the toradex easy installer image of Torizon OS to tcbdir/ path
Downloaded the Linux kernel :-
git clone -b toradex_ti-linux-6.6.y git://git.toradex.com/linux-toradex.git linux --depth 1
Downloaded the device tree overlays :-
git clone -b toradex_ti-linux-6.6.y git://git.toradex.com/device-tree-overlays.git device-trees
Created a configuration file (tcbuild.yaml):-
:penguin: root @GalaxyBook/home/Meenakshy/Projects/SPI_TFT_Display/tcbdir: cat tcbuild.yaml
input:
  easy-installer:
    local: torizon-docker-verdin-am62-Tezi_7.3.0+build.18
customization:
  device-tree:
    \# >> Directories where to look for include files.
    include-dirs:
      - linux/include/
      - linux/arch/arm64/boot/dts/ti/
    \# >> Custom device tree source:
    #custom: linux/arch/arm64/boot/dts/ti/k3-am625-verdin-wifi-dev.dts
    overlays:
      add:
        - device-trees/overlays/verdin-am62_msp3520_tft_display_spi2_overlay.dts
output:
  \# >> (2) Parameters for deploying to an Easy Installer image.
  easy-installer:
    \# >> Output directory of the customized image (REQUIRED):
    local: custom-torizon-docker-verdin-am62
    \# >> Information used by Toradex Easy Installer:
    name: "Torizon OS - SPI2 Enabled"
Directory structure will be :-
tcbdir
├── linux
├── device-trees
│ └── overlays
│ └── msp3520_tft_display_spi2_overlay.dts
├── tcbuild.yaml
└── torizon-docker-verdin-am62-Tezi_7.3.0+build.18
Build :-
torizoncore-builder build
Deploy :-
Deploy image to board :-
torizoncore-builder deploy --remote-host 192.168.0.131 --remote-username torizon --remote-password torizon --reboot
I couldn’t see my overlay got applied. SPI2 is not enabled. Also, UART4 didn’t get disabled.
Kindly help me to resolve this issue.
Issue Analysis and Solution
Looking at your device tree overlay and configuration, there are several issues that need to be addressed to properly enable SPI2 on your Verdin AM62.
1. Missing Required Headers
Your overlay is missing essential header files (1). You need to include:
#include "k3-pinctrl.h"
(1)
2. Device Tree File Path Issue
In your tcbuild.yaml, you have commented out the custom device tree line (2). For Verdin AM62 with development board, you should specify:
customization:
  device-tree:
    include-dirs:
      - linux/include
    overlays:
      add:
(2)
3. Corrected Device Tree Overlay Structure
Based on the Toradex documentation structure (1), here’s the corrected overlay:
/dts-v1/;
/plugin/;
    compatible = "toradex,verdin-am62";
&main_pmx0 {
            AM62X_IOPAD(0x01a4, PIN_OUTPUT, 1) /* SPI2_CS1 - SODIMM_30 */
&main_uart4 {
    status = "disabled";
&main_spi2 {
    pinctrl-names = "default";
    #size-cells = <0>;
    msp3520_display@0 {
        reg = <0>;
    msp3520_touch@1 {
        reg = <1>;
(1)
4. Build Process Verification
Follow these steps to ensure proper deployment (3):
  1. Verify your directory structure matches exactly:
tcbdir/
├── linux/
├── device-trees/
│   └── overlays/
│       └── verdin-am62_msp3520_tft_display_spi2_overlay.dts
├── tcbuild.yaml
└── torizon-docker-verdin-am62-Tezi_7.3.0+build.18/
(3)
  1. Build the custom image:
(3)
  1. Deploy the custom image (not just the overlay):
(3)
5. Verification Steps
After deployment, verify the changes:
  1. Check if SPI2 is enabled:
ls /dev/spi*
  1. Verify UART4 is disabled:
dmesg | grep uart
  1. Check overlay application:
cat /proc/device-tree/compatible
Key Points to Remember
  • Always uncomment the custom: line in your tcbuild.yaml to specify the base device tree (2)
  • Include all required header files in your overlay (1)
  • Deploy the entire custom image, not just the overlay (3)
  • Ensure your overlay file path matches exactly what’s specified in tcbuild.yaml (3)
This should resolve your SPI2 enablement issue and properly disable UART4 as intended.
Hi @Meenakshy
Can you try:.
  1. Build the image
  2. Unpack the new image
    torizoncore-builder images unpack custom-torizon-docker-verdin-am62
  3. Remote deploy
Hi Allan,
Thanks for the response.
The suggested solution worked perfectly.
Thanks & Regards,
Meenakshy K M
