It looks like you’re encountering an issue with the Docker build process, specifically when trying to load metadata for the base image localhost:5002/qt6-wayland-imx8:3.3.1. The error message indicates that Docker is unable to connect to the local registry at localhost:5002.
Here are a few steps to troubleshoot and resolve this issue:
Check Local Registry:
- Ensure that you have a Docker registry running on
localhost:5002. You can check this by running:docker ps - If the registry is not running, you can start it with:
docker run -d -p 5002:5000 --name registry registry:2
Verify Image Availability:
- Make sure that the image
qt6-wayland-imx8:3.3.1is available in your local registry. You can list the images in your local registry by:curl http://localhost:5002/v2/_catalog
Correct Image Reference:
- If the image is not in your local registry, you might need to pull it from a remote registry or build it locally. Ensure that the
FROMstatement in your Dockerfile points to the correct image location.
Network Configuration:
- Ensure that there are no network issues preventing Docker from accessing
localhost:5002. You can test connectivity by:curl http://localhost:5002/v2/
Use Remote Registry:
- If you do not need to use a local registry, you can pull the base image from a remote registry. Modify your Dockerfile to use the correct remote image reference.
Dockerfile Example:
- Here is an example of how your Dockerfile might look if you are pulling from a remote registry:
FROM torizon/qt6-wayland-imx8:3.3.1 # Add your application build steps here
Rebuild and Push:
- After ensuring the base image is accessible, try rebuilding and pushing your Docker image again:
docker build -t my-qt-app . docker tag my-qt-app my-dockerhub-user/my-qt-app:v1.0 docker push my-dockerhub-user/my-qt-app:v1.0
Run and Enable Service:
- Once the image is successfully pushed and pulled, you can run it and enable it as a service:
docker run -d --name my-qt-app --restart=always -v /dev:/dev --privileged my-dockerhub-user/my-qt-app:v1.0 sudo systemctl enable my-qt-app.service sudo systemctl start my-qt-app.service
If you continue to face issues, please provide more details about your Dockerfile and the exact steps you are following, so I can assist you further.
