The Toradex website states that connman is used for ethernet network configuration. As there is no explicit manual configuration file in /var/lib/connman/<service-name>.config I assume that the default configuration of connman is used then. The connman documentation mentions that the “default configuration method for all services is automatic or something like DHCP”.
I tried to figure out the default configuration with different network configurations (e.g. TK1 connected to Router and internal network):
root@apalis-tk1:~# connmanctl services
*AO Wired ethernet_00142d2bd8a0_cable
root@apalis-tk1:~# connmanctl services ethernet_00142d2bd8a0_cable
/net/connman/service/ethernet_00142d2bd8a0_cable
(configuration settings varies with network configuration)
It seems like the TK1 has assigned a static ip of 192.168.11.1 (ping-able with ping 192.168.11.1) and gets the ip address via dhcp if connected to a network with dhcp server running (ping-able with ping <dynamically-assigned-ip> and ping apalis-tk1.local). The TK1 is also accessible over link local (ping-able with ping 127.0.0.1 and ping apalis-tk1.local.)
- Is that correct?
- For the case that the configuration in the Apalis Image differs from connmans default behaviour: Can I find more information on some Toradex website?
