Dealing with torizoncore-builder
I have different issue when I try to deploy Torizon OS with one container on a IMX6ULL colibri.
here my tcbuild.yaml:
input:
easy-installer:
local: image/torizon-docker-colibri-imx6ull-emmc-Tezi_7.4.0+build.28.tar
customization:
filesystem:
  • overlay1/
output:
easy-installer:
local: output_directory
EOF
I build image with:
torizoncore-builder build --file tcbuild.yaml --force
I use TEZI to flash the IMX6ULL. All work without issue, but image is deploy on target with registry naming convention:
docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
localhost:5002/torizon_prod 02b67feba2a0 3 days ago 116MB
I would like that the deploy process directly deploy torizon_prod image.
I guess it’s because I use localhost:5002/torizon_prod for the image in my bundle, but torizoncore-builder only want images in registry.
I know I can ‘docker tag’ on host with correct name but I would like this action made in deploy process.
Any clue ?
I see you’re encountering an issue with container image naming when using TorizonCore Builder to pre-provision Docker containers. Based on your configuration, you’re only using filesystem customizations but not actually pre-provisioning containers through the proper TorizonCore Builder method.
Understanding Container Pre-provisioning with TorizonCore Builder
To pre-provision Docker containers onto a Torizon OS image, TorizonCore Builder provides specific configuration options in the output section (1). Your current tcbuild.yaml only includes filesystem overlays but doesn’t specify container bundling.
Proper Configuration for Container Pre-provisioning
Method 1: Auto-Pull Containers from Docker Compose
You can configure TorizonCore Builder to automatically pull and bundle containers by specifying a Docker Compose file (2):
output:
  easy-installer:
    local: <path>
    bundle:
      compose-file: custom/docker-compose.yml
(2)
Method 2: Pre-bundled Container Directory
Alternatively, you can pre-bundle containers using the bundle command and then reference the directory (1), (2):
  1. First, create a bundle from your Docker Compose file:
$ torizoncore-builder bundle docker-compose.yml --bundle-directory bundle --platform=linux/arm/v7
(1)
  1. Then reference the bundle directory in your configuration:
output:
  easy-installer:
    local: path/to/your/custom-image-folder
    bundle:
      dir: bundle/
(2)
Complete Configuration Example
Here’s how your tcbuild.yaml should look to properly pre-provision containers:
input:
  easy-installer:
customization:
  filesystem:
    - overlay1/
output:
  easy-installer:
    bundle:
      compose-file: docker-compose.yml  # or use 'dir: bundle/' for pre-bundled
Platform Specification
Since you’re using an i.MX6ULL (32-bit ARM), make sure to specify the correct platform when bundling (1):
$ torizoncore-builder bundle --platform=linux/arm/v7 docker-compose.yml --bundle-directory bundle
(1)
This approach will ensure that your containers are properly integrated into the Torizon OS image during the build process, eliminating the need for manual Docker tagging after deployment.
I tried this method but container image on target always have localhost:5002/app:arm
This is a “registry naming”, when I try to docker run this image it doesn’t start.
I expected a image tag without localhost:5002 in its name.
@ToradexAI
I tested your solution but I always have localhost:5002/torizon_prod images on container that cannot be run.
Understanding the Container Naming Issue
The localhost:5002 prefix you’re seeing is part of how TorizonCore Builder handles container images during the bundling process (1). This is expected behavior when TorizonCore Builder creates a tarball containing all the containers and generates a Docker Compose file referencing those containers using a specific hash (1).
Root Cause of the Issue
The issue you’re experiencing relates to how the bundled containers are referenced in the modified Docker Compose file that TorizonCore Builder generates (1). When TorizonCore Builder bundles containers, it creates a modified version of the Docker Compose file that references the container images with specific registry paths (1).
Solution: Verify Your Docker Compose File
To resolve this issue, ensure your original Docker Compose file references the container images correctly before bundling. The container images in your Docker Compose file should be referenced by their intended names, not with the localhost:5002 prefix.
For example, your docker-compose.yml should look like this:
services:
  torizon_prod:
    image: torizon_prod:latest
    # other service configurations
Alternative Approach: Use Variable Substitution
You can also use TorizonCore Builder’s variable substitution feature to manage image names more flexibly (2). This allows you to define variables that can be substituted during the build process:
services:
  app:
    image: "${IMAGE_NAME:-torizon_prod}:${IMAGE_TAG:-latest}"
(2)
Then run the build command with variables:
$ torizoncore-builder build --set IMAGE_NAME=torizon_prod --set IMAGE_TAG=latest
Troubleshooting Steps
  1. Check your original Docker Compose file - Ensure it doesn’t already contain localhost:5002 references
  2. Verify the bundle process - The bundle command should create a directory with both the container images and a modified Docker Compose file (1)
  3. Review the generated compose file - Check the compose file in your bundle directory to see how the images are being referenced
The localhost:5002 naming convention is part of TorizonCore Builder’s internal process for managing bundled containers, but the final deployed containers should be runnable with standard Docker commands once properly configured.
Here my real docker-compose.prod.yml
version: “2.4”
services:
torizon_buoy:
image: torizon_buoy_prod:latest
container_name: torizon_buoy_prod
restart: always
working_dir: /home/torizon/app
devices:
  - /dev/colibri-i2c:/dev/colibri-i2c
  - /dev/colibri-uarta:/dev/colibri-uarta
  - /dev/colibri-uartb:/dev/colibri-uartb
  - /dev/colibri-uartc:/dev/colibri-uartc
  - /dev/rtc:/dev/rtc
  - /dev/ttyUSB0:/dev/ttyUSB0
  - /dev/ttyUSB1:/dev/ttyUSB1
  - /dev/ttyUSB2:/dev/ttyUSB2
  - /dev/ttyUSB3:/dev/ttyUSB3
volumes:
  - ${SDCARD_DIR}:${SDCARD_DIR}
  - /local/user/etc/torizonbuoy:/home/torizon/app/.buoy:rw
cap_add:
  • SYS_TIME
the application name is torizon_buoy_prod and i want tag latest
I get this error when running bundle command:orizoncore-builder bundle --platform=linux/arm/v7 docker-compose.prod.yml --bundle-directory bundle
Creating Docker Container bundle…
NOTE: TCB no longer expands environment variables present in the compose file.
Starting DIND container
Using Docker host “tcp://127.0.0.1:22376”
Connecting to Docker Daemon at “tcp://127.0.0.1:22376”
Fetching container image torizon_buoy_prod:latest in service torizon_buoy
Stopping DIND container
Error: container images download failed: 404 Client Error for https://127.0.0.1:22376/v1.44/images/create?tag=latest&fromImage=torizon_buoy_prod&platform=linux%2Farm%2Fv7: Not Found (“pull access denied for torizon_buoy_prod, repository does not exist or may require ‘docker login’: denied: requested access to the resource is denied”)
Hi @didier2018!
Were you able to solve this issue? If so, could you please share how you did it?
Best regards.
I don’t remember exactly what I did but most of my problems was due to Fedora and its SELinux / Filesystem management. I uninstalled the native Fedora docker to install the official docker CE and make docker image storage a independant virtual disk:
/var/lib/docker-ext/disk.img on /var/lib/docker type ext4 (rw,relatime,seclabel)
Others problems was my misunderstanding of how TCB work.
