I would like to fix the used Linux kernel version.
So I plan to deactivate head_next within th recipe to prevent versions like:
3.10.40+gitrf328e55a793497870c533eac0ac21cb735a82e6d-2.7.3.
Can you recommend this?
Kind regards
Dirk
Kind regards
Dirk
In regular builds use-head-next
should not be in the machine overrides variable. Toradex usually add that through a MACHINEOVERRIDES =. "use-head-next:"
in local.conf
for Continous Integration. So the Linux kernel version should be fixed by the two variables SRCBRANCH
and SRCBRANCH
Currently SRCBRANCH_use-head-next = “toradex_tk1_l4t_r21.6-next” is set within linux-toradex.bb
For CI purposes I should outcomment it, right?
OpenEmbedded uses something called “variable override”. Variable overrides are denoted by _
So in this case we have a variable override of the variable SRCBRANCH
in case use-head-next
is set. However, unless you explicitly set use-head-next
in your local conf, it won’t be set… So you should be fine without uncommenting that line.
So, unless you added use-head-next
in your local conf, the line won’t be active anyway.
